Sierra 2.0 DOHC 8V Idle Problem ( HELP )
At the moment I have checked the Idle Control Valve and it works perfect. My problem started when the car would idle at 1100rpm. I disconnected the Throttle Position Sensor (TPS) It would idle at 800rpm. It runs fine when disconnected but a pig on juice. Got a known working second hand TPS and once I plug that in the car jumps to 1100rpm idle. Once I go to move the throttle cable to rev it it instantly cuts out. Anyone any ideas as to what the problem is ?
While engine is RUNNING I have disconnected the Temp Sensor for hot and cold start. ( Lets ecu know if engine is hot or cold ) and it makes no difference. Does that indicate that the sensor is at fault ?
Thanks
Thanks
If you start unplugging sensors, then you can never expect it to run correctly with them unplugged.
So you're chasing your tail there.
What exactly was the initial problem ? And how are you testing the ICV to say it is working ?
And if the TPS is movable in anyway, is it installed and set correctly ?
You then suggest another running problem, not just idle ? So there are multiple problems here ?
Not entirely sane
Have a look at the small rubber pipe at the bottom of the crank case breather pipe where it joins the PCV out of the crank case. They get cooked by the exhaust and can fail. This leads to a big air leak into the inlet which screws with the idle speed and mixture as it isn't being measured. The hose is about 15 mm diameter and about 30 mm long, surrounded by a sheet metal heat shield.
