fitting oil gauge sensors to a cosworth lump
ELASTIC BAND
got my oil pressure and temp gauge to fit, got a T piece to fit both sensors, but where on the block do they go?
Ive seen some people have fitted it just above the oil filter, but on my engine ive got a braided pipe from the turbo plumed in there, i think. Plus accessing it it crap, just no room?
is there anywhere else people fit them thats easy to do?
i fitted my 2wd yb where the oil pressure switch goes inbetween where the starter and mowdime/oil filter area. theres adapters/fittings on ebay it will take the oil pressure switch as well i think it comes of the main oil gallery there. feed the pipe through the bulkhead on the same side theres a handy grommit near the top over the ecu happy days
I used a remote braided jobbie from Burtons from oe oil port in block, then used a 3 port block, mine is on an escort and I have my oil feed/AIM oil sensor and oe VDO unit on there, mounted the port block by making a bracked and using a p clip next to the engine mount
ELASTIC BAND
I just cant get at it from above, well i cant see what or where im trying to get to from above?
Is that where the factory oil light sensor is? As i cant even see a wire going to anything around that area?
