Had tracking done this morning, now power steering light on, abs on, steering is hard
I replaced the drop links on my car yesterday as I hit a pothole about 2 weeks ago which damaged the old ones.
got tracking done this morning at suspension shop , they didn't use lasers just some sort of hand tool.
all was well up until a few hours later, battery light was staying on but everything felt fine.
got in my car again about an hour ago, battery light stayed on still but then the ABS would come on, then off, then on e.t.c. next the power steering light came on and my steering felt very heavy I could hardly turn the wheel !
I rang said suspension shop who said they cannot think of how doing tacking could cause this but to try and bring it in and they will have a little look, but now my battery is flat and my power pack is flat also so that is currently on charge !
any ideas why the battery, ABS and power steering light would all come on after getting the tracking done ?
thanks to all in advance
Sounds like the auxiliary belt has come off/snapped? Or it's a smart charge alternator and that's up the spout. I seem to remember u saying u had loads of probs with a flat battery
There's some good advice in the tag section
thanks for your kind reply.
I was on my way back to suspension shop around 2 hours ago ( driving very carefully) but as we got not far from it all the lights on the dashboard come on and temp gauge fluctuating up/down and the speed meter wasn't showing my speed, just showed 0. then while driving show the car just shut off. I had to park car and walk to suspension shop, as my car was a few streets down and once I told him everything he said what I thought that perhaps the alternator, I bought a brand new battery from a shop around the corner that was almost ready to close ( cost £75, £23 more than my local shop) and was able to drive it home, kwik fit tested the charging and said it wasn't giving any charge at all so said it could be alternator.
Since putting new battery on everything has gone okay, steering fine e.t.c. but battery light has strayed on.
I am now looking at used alternators and will prepare myself a week or so though hopefully it'll take much less time for me to fit a new alternator on my car.
any advice ?
cheers in advance
Burn it
not sure if it is a smart charger alternator or not.
After having brand new battery fitted all lights went off apart from battery light, kwik fit tested for free, said no charge was giving out so possibly alternator.
how do I check the serpentine belt is in good condition ? do I get under the car and turn the belt somehow to make sure it hasn't slipped off anywhere, do I tighten the tensioner ???
thanks
Does it say "triggers broom" on the log book?
is it possible it is a slipped serpentine belt, how would I check for this ?
thanks in advance
Bound to be the belt, just look for a pulley without a belt on it
Alternator is toast mate. Auxiliary belt has a tensioner on it so it's not a stretchy belt. Power steering is run by an electric pump under the drivers headlight and is the first thing to stop when the alternator dies. It is a smart charge alternator and I really would advise getting a genuine one.
hi, thanks for replying
if the pulley does not have the belt on it does that mean the belt has slipped off ?
when I get under the car, remove the under shield, how do I turn the belt to inspect it ?
how would I put on the belt if/were it has slipped off ?
thanks
thanks
power steering light came on, then abs, then every other light came on, then the speed meter stopped working, then driving at low speed the car cut out and when trying to turn the key all I could hear was a loud clicking noise like machine gun. bought a new battery from car parts shop and it turned all lights off apart from the battery light, had a shop check for alternator failure, he said the charging system was putting out zero charge and said it may be a bad alternator.
could all this be due to a bad belt and not a alternator ?
thanks
thanks
thanks
thanks
Use a belt from your jeans to replace the snapped belt , but be warned it may run a little lumpy as buckle runs over the pulley
Hope this helps
Cheers Paul lol
Hope this helps
Cheers Paul lol
Caddyshack (17-02-2017)
So possibly blaming someone doing wheel alignment....vs the 7893752 hours of butchery you've done to the poor car over the past year or so ?
Seriously, just get rid of the damn thing !
the temperature gauge did fluctuate going near red then back to half way, but I think system has airlock somewhere but also I notice it is not blowing hot air since this problem started, only cold air.
what if the belt hadn't snapped but just came off slightly ?
I will fit alternator myself if it needs doing and can get a used one from Ebay for around £30 and a serpentine belt for around £10
thanks
THE REAL DEAL
like i have said before take it to a garage, if you cant afford it then you should not have a car as unfortunatly running one is an expensive business, doing all these bodge up repairs makes you a danger and menace to other road users,
1st to 200 without NOS
any advice ?
advice on replacing alternators, where is the tag section ??
Maybe you should go there with a couple of buckets big enough to fit your feet in and a bag of ready mix concrete, it will solve all your problems
Tags are full...
Booooooooo
Booooooooo
Err wtf is a serpentine belt?? The only serpentine I know is a section of the Thames river in London where you can go for a swim.
As said I have spent over £9,000 on car repairs in almost 5 years. I easily afford to run a car , I always have my fuel tank full to capacity, I can easily afford to go to a garage but, why should I ? I've been ripped off enough and I actually enjoy fixing my car and seeing how it is all put together.
All the repairs I've done have been done to a satisfactory standard, in fact any problems I've had have been jobs previously done by other people, overall I would say I'm better overall when a repair job has been completed than the so-called mechanics who have ''fixed'' things on it in the past.
cheers
hi, nice to see you.
It seems the problem was the fan belt/serpentine belt.
I bought a new belt but am struggling to put it on, like when trying to slot the ribbed belt onto the ribbed pulleys when I let go it simply falls off ! how is one supposed to put the belt on without it coming off the second you let go ?!
I've improved access top and below so access is good, just can't figure how to get said bolt to stay on .
cheers
cheers
