Cosworth YB 500 BHP compression
#81
Happily retired
Whether the RS500 touring cars could have run better with todays technology is not important to me. At the time they made for very exciting racing and were at the top of that periods tuning level.
This thread has turned into a low comp v high comp argument. If the guys who are running low comp big power engines are happy and the guys who are running high comp engines are also happy does it really matter?
Budgets are also important to a lot of people, everyone would love a 700bhp road going Cossy but not many can afford it.
#82
i'm following this thread and seeing what people come up with, i'm building a 32v v8 5.4 ford engine, that will be fed by 2 gt35r turbos, i have decided to go for a cr of 9.3:1, the bottom end will be good for at least double the power it will be running, so although the engines are different, the principal is the same
#83
Lol toby you correct arrogance seems to have a wide band on this forum and also not listening. My point was that the average person and some tuners say and believe that at 500 -600 you need to go lower comp than standard to achieve this which is bollocks and Mark and dave have stated 700 bhp at 8 5 on pump an yes at 10.1 race fuel and higher revs do the job but that's comon sense lol
Cheers Paul
#84
It's not the location im talking about, but the fact that the mixture is ignited from the centre and outwards. This is slow and inefficient as the flame front has to travel a great distance before all the mixture is ignited.
#86
At a guess I'm saying other people would of and have, otherwise they'd choose something different surely?
Cheers Paul
Cheers Paul
#89
This design has been unchanged since the 1950s, and is currently being revolutionized by TJI. +15% efficiency, 1/3 reduction in fuel consumption, lower EGTs etc. Follow F1 and you get updated on the latest tech.
And all these newfangled things always make big claims, reality often proves different. Hence why engines have changed so little over the past few decades.
#91
To get the most out of it you need direct injection, but you would still see a huge gain over conventional spark plug on a port injected system. Remember, it's all about avoiding knock. The distance the flame has to travel directly dictates when ignition has to occur. Being able to ignite all the mixture at once allows for higher compression ratio = higher efficiency = less fuel per hp.
Direct injection also have a major flaw, which is carbon build up in the intake ports as the port injector is no longer flushing / cleaning the ports. Look at N54 and the issues with DI.
To retrofit TJI on a YB we would need a high pressure fuel system for the prechamber ignition, and a specially designed tji-injector that fits in the stock spark plug hole. There's room for such a system in the YB head.
#92
For maybe 20-30k they might remain clean and efficient...after that they're bound to be going downhill.
Modern cars really are turning into bundles of shite, forced because of silly emissions targets which I'd say can be counterproductive because the technology is so poor and unreliable for long term cleanliness.
#93
Yes most direct injection engines suffer from carbon build up in the ports, but to me this is pretty easy to almost completely overcome, just fit a breather system that doesn't re burn the breather gasses, and I expect it would almost stop the issue altogether, but again the reason that isn't done is due to emissions and not being legally allowed to run open breathers.
#95
What comp ratio did the cossie have that you drove buddy?
Was it mega low comp?
Cheers Paul
Cheers Paul
#96
I often find (found) that owners are happy with what they have because it was the dogs bollocks when they splashed the cash, but it doesn't mean they're any good.
#97
If you could run a turbo car at the same comp ration as the best n/a car then you would, if it didn't melt then you would do it so surely the highest comp ratio that you can get away with is the best?
#98
Mark
#99
Wow, that is pretty big.
#100
When can we start? Lol
That is bonkers, how do they stop it melting?
#101
#104
Question i want to ask everyone is, with regards to the old YB what do you think has changed in the tuning world in the last 15 years to allow higher compression ratios to be used?
#109
**RS COSWORTH**
#111
Coil on plug moved things on.
If you doubt it just look at what had to be done for 500 bhp in the 90s, now a standard engine can do it.
#113
**RS COSWORTH**
#114
Mark
#115
i don't agree with any of your points!
very modern ecus may well be faster, but the question should be how fast do they need to be? engine speeds haven't changed, 15.4 degrees of ignition advance was the same in the 90's as it is now!
#116
So, Gareth, what is your point? Cars are making far more power, failing less and running a higher compression. What is your argument?...should we all be running lower comp and to what end?
#118
**RS COSWORTH**
They done a great job for what they had available for there days. Things have moved on since the 80's.
#119
my point is for people to stop being so blind into thinking things has significantly moved on in the yb tuning world.
You should run the highest compression ratio you can.
#120
A few things I have learned from 4 years on this forum 1) Mark Shead knows his onions. 2)listen to what Mark Shead is telling you and 3) Cosman likes bumming things.
