Power steering stuff when cold?
Old Jan 2, 2017 | 02:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default Power steering stuff when cold?
Once I've turned out a few times it's fine, but even if I leave the engine running fit a few minutes it's still almost impossible to turn at first and then it's a bit notchy and then 30 seconds later it's fine
Levels are fine
On my mk 6 Fiesta
Old Jan 2, 2017 | 07:35 PM
ray barker's Avatar
ray barker
its either the pump or the rack shagged both can give similar probs is the pump noisey as fuk if not i would lean more towards the rack to keep cost down buy a recon rack get a second hand pump i did a 306 pug once and thepump chewed one of the seals up pushed it in the rack the rack have fine mesh gauses in them blocked it up check your power steering pipes arnt pinched or the banjows arnt kinked asumeing its not electric
Old Jan 2, 2017 | 07:37 PM
Stuff?????????
Old Jan 2, 2017 | 08:55 PM
RichieST's Avatar
RichieST
Drain some fluid out of the bottle and see if there is a gauze filter in there. If so it's probably clogged. Take the bottle out and clean it with degreaser and the wife's toothbrush. That'll teach her for stitching you up with the mother in law.
Old Jan 3, 2017 | 05:33 AM
dojj's Avatar
dojj
The pump is quiet as a mouse
And after a few turns the rack is as good as gold
It's a bit cold to do anything else at the moment so I'm waiting for it to break and then get the AA to fix it
Old Jan 3, 2017 | 09:08 AM
tosh's Avatar
tosh
"Get the AA to fix it" that's a laugh dojj! All they do these days is send three people to look at it before they stick you on a flat bed and take you home. ��
Old Jan 3, 2017 | 07:05 PM
dojj's Avatar
dojj
Wasn't cold this afternoon, steering was fine
Was cold @4am steering was being silly buggers
Old Jan 3, 2017 | 07:37 PM
ray barker's Avatar
ray barker
you could try changeing the fluid if the cars quite old just pull the return of the resevoir start it turn steering slightly catch the old crap in bucket just shuv a bit of longer pipe on it and at the same time pour in the new stuff in the res
Old Jan 3, 2017 | 08:19 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Tottaly different but the steering fluid on are old fork lift had never been changed. One winter turns out it was contaminated with water we guessed it must have been condensation from the oil getting hot and cold over the years. It froze one winter and fucked the pump and its drive gear.
Old Jan 3, 2017 | 08:56 PM
gcfcos's Avatar
gcfcos
Same thing happened to my mates saph cos, he has a stainless p/s tank and it always seemed to condensate inside and then the p/s fluid milky. I've mentioned it to a couple of people on theirs. He's gone through a pump and rack now
Old Jan 3, 2017 | 09:04 PM
ajamesc's Avatar
ajamesc
The steering oil in are fork lift looked like pink slush puppy lol. I did the job engine out torque converter off then the gear that drove the pump was chain driven off the crank. Gear was repaired via spray metal as the splines inside that the pump shaft sat in had stripped
Old Jan 3, 2017 | 11:15 PM
gcfcos's Avatar
gcfcos
Yep exactly what my mates fluid kept going like. Told him to get rid of the stainless tank and it hasn't done It since.
Old Jan 5, 2017 | 07:29 AM
dojj's Avatar
dojj
Fluid charge when the weather's warmer then
Don't want to make a mess on the garage floor now do I
Old Jan 5, 2017 | 07:30 PM
ray barker's Avatar
ray barker
for some reason stainless absorbs water or sumut like that i couldnt understand why the saff got more steamey in the winter for a while i thought the h/g was on the way i kept pressure testing it every thing was mint talking to somebody who take them smart ass tablets its the stainless exhaust summer time not a prob
Old Jan 5, 2017 | 08:11 PM
gcfcos's Avatar
gcfcos
Yeah my Cossie steams a lot when it's cold or been sat for a while with the stainless exhaust
