Cossie 2wd exh manifold
#85
Let's say you already own an engine, a rebuild is £3k before you do much to it, then port the head, chuck some nice Pistons, a cam and some long studs at it, maybe a crank and buy the Borg and the pay for a decent ecu and mapping, what is that £7k to £10k?, maybe more. Why not pay another £1k on the proper manifold? Sell the donor manifold for whatever you can get.
#88
Live long and prosper!!
Mad_Mat (04-04-2016)
#91
New Owner
Hopefully Jay gets something knocked up and will share his results.
Personally I could not justify the 1k on the tubular if the modified 2wd is 90% as good for a minimal comparative cost.
pduane (22-04-2016)
#93
My thoughts exactly shouldn't be massively expensive to get 50 made or something like that, it would also be stronger as all these tubular manifolds will never be as tough as a cast one.
#94
cossie fan (unluckerly)
I guess that all comes down to the quality of the metal your tubular one is made off.
james kiely (02-04-2016)
#99
It will never be as strong as a cast manifold imo, I've had plenty of trouble with tubular turbo manifolds cracking and braking, I'd choose cast anyway my gtr is on stock manifolds, I'm sure a 2wd manifold wouldnt be to restrictive unless going for silly power imo
#100
#101
Mark
#106
No, been looking at this conversion but as said its a big lump of cash to fork out for turbo and manifold in one go, was just thinking if you could get the turbo going on the car first then swap the manifold at a later date, but if you had to map it twice it would end up costing the same so no gain.
#108
it only really needs a t4 flange welding on, then if you need to angle it away from the motor abit for clearance why not have a wedge shape thin spacer made to go on the manifold join and angle it away to the needed position, would be easy to mock up with spacers for desired fitment then just have a piece cut to the correct thickness will cost very little that way then, or cut the bottom flange off and reweld it to the desired angle to move the turbo where its needed
#109
Would be really interesting to see what power a middle of the range efr does on a standard 2wd manifold compared to a tubular item....
Someone do it! Ha ha
Cheers Paul
Cheers Paul
#113
I saw a escort Cosworth at croft last year with a nms trouser section that was twin scroll for a gt35/40 (can't remember which one) looked a nice piece of work and the car was good power can't remember exactly but somewhere in the region of 700 bhp.
#119
lol I take my advice and opinion of the tuner I use and when he talks about the massive improvement in low down torque and response and you see the real results he gets I'm ok with spending a little more. The horse power number is good but the torque number and how low down it builds torque and horse power is the bigger picture
#120
New Owner
I expect Cosworth did plenty of development work on getting the spec of the 2wd manifold right in the first place so I wont be surprised if it performs pretty well in comparison to the tubular.
Great if it does
Great if it does
