Turbo blankets ?
I think the zircotec type coatings may be better?
Happily retired
its the underbonnet temps the problem,had heat wrap around it before,but looks untidy.Would the coating not keep the heat in and damage the turbo ?.
Ive seen plenty of turbos coated
If you buy a good quality blanket, it will last a long time.
If you buy crap, it wont
It really is as simple as that. And never had any issues on any ceramic coated turbos. But the coatings will not reduce heat radiated as much as a turbo blanket will, simply because there is a physical barrier with the blanket.
JK12
33
26-04-2021 12:09 PM
