Escort Cosworth - Steering wheel fitment- HELP!!!!
Hi All
Yet another quick job not going to happen. When I got my car it had an after market steering wheel on it along with other modifications but all the standard bits came in a big bag.....this is were my problems start. I think that there are 2 steering wheel bosses in the bag and I can't work out how it goes back together with the standard steering wheel. I have remove the horn power plate from the modified wheel boss and fitted it back to the standard steering wheel, does the wheel then just push on the shaft and get held in place with the nut. There appears to be a plastic ring (?) on the shaft that get pushed out of shape if i do this? Then theres all the bits of wire I have for the horn switch
Anyway you get the picture any help would be much appreciated ...
Thks Malc
Thks Malc
on the steering wheel boss on the rear there should be a plate that the horn wires connect to held in by three screws this needs to transfered to what ever wheel your fitting the plastic notch thing needs to be on the same sides as the indicator stalk as this is the auto canceler thing,hope this helps
HI
Thks, but I am trying to put the standard wheel back on .....does anyone know how to fit a standard steering wheel from the plastic ring on the shaft back so to speak!!
Thks
Malc
Thks
Malc
Like he says there m8
just screw on the plate which is held on by 3 screw( take this off the old boss) and then it just drops down onto the thread and do it up
There is no seperate boss with the ESC steering wheel
Ok thks Chris...But does the thread have a white plastic spacing ring around the base when the standard steering wheel is used?? It just seems that this is getting squashed and not letting the wheel locate but it does look like a standard Ford part which is why I am struggling. I will get some photos done, probably a better way to check...
Thks for the help I know its not the most exciting topic
Cheers Malc
Cheers Malc
Jack and the Beanstalk
15-08-2015 04:27 PM
