brake issue on xr3i
brake issue on xr3i
since im nearly close to getting the car on the road i have one last problem with it im hopeing someone can advise on if possible
when the brake pedal is depressed it goes nearly all the way to floor before it starts to brake the wheels
i appriciate its 30 yrs old and i have just cleaned out all the brake fluid and replaced and bled the brakes as was told the brake fluid may be the problem (it was black lol) this hasnt solved the problem its still the same
its had all new brake pads and wondered is this normal on old cars or could a part need replacing as it does stop but just seem right to me
also it did pass the mot last yr with the brakes like this so must be good enough to pass the brake test
any help or advise would be great thanks
phil
phil
1st to 200 without NOS
phil
phil
Do this stationary, NOT whilst driving
but the pedal to the floor issue existed before doing the fluid change so its no different
also i have checked calipers and both move easily
Are the rear brakes correctly adjusted? As said above clamp the hoses.
If you have 4 hose clamps, clamp all the hoses if the pedal goes solid remove the clamps from the hoses one at a time, each time testing the pedal pressure, as soon as it goes soft you know which corner the issue is at.
If the pedal isn't solid with all the hoses clamped then the master cylinder is probably knackered.
many thanks
The Enigma
12-09-2015 10:12 PM
