RS Turbo problems
Old Aug 16, 2013 | 04:38 PM
Ryan_RST's Avatar
Ryan_RST
Default RS Turbo problems
Hello all,
I have a 1898 series 2 RS Turbo, which will not idle? It will start from cold with help from throttle but don't idle on its own, when it gets warm it will not start at all? This first started when I was driving down the road and she just cut out and wouldn't start till cold? Can anyone help?
Thanks in advance
Old Aug 17, 2013 | 07:26 PM
Marc D's Avatar
Marc D
Probs best get it to a specialist mate. Could be anything from the fuel mixture or timing to dodgy wiring or knackered ecu
Old Aug 17, 2013 | 08:36 PM
Eagle's Avatar
Eagle
Super Moderator
could be an air leak if it will not idle correctly, they are very annoying like that..
have you tried removing the idle valve on the inlet and cleaning it ?
Old Aug 18, 2013 | 10:54 AM
Ryan_RST's Avatar
Ryan_RST
The brake servo is cracked I think that is what's causing it not too idle? Could that be it?
Old Aug 18, 2013 | 11:43 AM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
It won't help as its vac assisted and the engines drawing in air from there, try blanking it off and see if it helps, these engines need as much vac pressure as possible hence there not fond of DVs
Old Aug 18, 2013 | 11:56 AM
scoobykilla123's Avatar
scoobykilla123
Hi sorry to thread jack mine cuts out on Tickover now and again...where is the idle control valve so I can clean it? Any pics please I'm no mechanic lol
Old Aug 18, 2013 | 12:06 PM
Ryan_RST's Avatar
Ryan_RST
ok well hopefully getting a new servo today anyway see how it goes,
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
