Escort Cosworth T5 conversion, whats needed
I hoping to get a T5 gearbox this week for my zetec turbo escos, i just want to know what i need to fit it as im dieing to get my engine in straight away
What gearbox carrier should i use? i know its a granada one but im not sure which.
I also need some gearbox too engine bolts, where can i buy these?
thanks matty
thanks matty
Hey mate, not sure if the box will line up the same with a zetec lump compared to a YB, but the mount I have used on my 4x4 Saff converted to 2wd with a T5 uses a mount available from ford. The finis code (ford part number) is 6177696 for the mount, saph with mt75 box £11 or so from Ford. This puts a 2wd box into the 4x4 chassis rails perfectly
pic of the mount:
pic of the mount:
You will also need a shortened 2wd prop shaft, sure there are a few people knocking around who know where to get one, Paul at North Yorks RS spares might be a good one to ask
[/URL]
[/URL]
once ive got the gearbox mounted to the engine i need the right mount so it gives my engine the correct possition so it should work out the same position as a standerd escos.
is that from a pinto'd engine'd saph as i know pinto mounts fit a zetec so i may not need to make custom mounts if a use a 2wd cross member
Escortdriver1
31-07-2015 02:36 PM
