torque settings for cossie cams and head??????????/
just wondered if anyone knew the torque settings for the cams and the head bolts on a 88 2wd saph
will these be the same for the 2wd cause when i bought the bits i was told there are 2 types of head bolts mine are the early ones apparently. O and any info on the cams
As for the cam caps have a look in the Technical Essay Archives forum.
All the workshop manuals are in there
Sorry, to lazy to look it up for you
i need to know for tomorrow or sunday at the latest really i think i might make a few phone calls tomorrow someone i know will know surely
cheers for this i need to know torque settings on the head bolts and the caps for the cams and anything else you can think of when refitting the head really
Re: torque settings for cossie cams and head??????????/
settings for the cams.....
Camshaft frontbearing caps to c/head 8-10nm.
Camshaft bearing caps to c/head 19-23 nm.
oil threads.
Head....
stg.1....45-50 nm.
stg.2...turn 180 degrees
stg.3..check for 110 degrees.
C/head cover bolts....10-15
think that is it
Dave.
your a star i can get cracking on with it tomorrow now
no problem mate, glad to help.
rs nuts Posted: Fri Mar 18, 2005 10:46 pm Post subject:
yes your right dave
Got the manual in front of me.
you should know then off by heart now Ian.
Dave.
