Zetec turbo help/advise
Old 04-07-2013, 11:37 AM
  #41
Smidydevil
Smidydevil's Avatar
Originally Posted by Karlos G
You've gone Gotech, what made you choose that?
Fair play mate, you must of got your rods and pistons real cheap as an ST170 engine can be had for less than £400.
LSD you need is an 8 bolt S2 not a 6 bolt S1.
Gearbox I think?
Don't get me wrong I think the st170 engine is a great way to do it ..
Yea well £40 for a known good engine, £80 for a set of Audi 1.8t pistons and £300 on steel rods and arp bolts with maching work included so not a bad price , should give me a 8.8:1 cr iirc
Yea I thought it was the s2 LSD thanks for clearing that up
I won't be changing to an MTX box . Too much money for a gearbox set up, I agree once they're in and sorted they are good n strong but not justifiable IMO at this moment in time. I will see how the Ib5 set up fairs first
I'm not doing this build on any particular budget as I know for one you'll never budget enough LOL but I will spend good money on the good parts I think are needed, such as management, internals, turbo etc and everything will be rigorously checked over and rebuilt before hand including the gearbox
Inlet manifould. What's needed to fit the blacktop inlet? Seems to be just all the original arrangement bolted on with a different cable possibly? I don't want to use the HO inlet as good as they are I want to be able to shut my bonnet lol so will look into the blacktop manifould and if not stick with the cvh efi one
Either way I do this I can use the Astra vxr Injectors in both I think ?
Il be happy with anything between 260-300bhp to be honest if I don't make 300 I wil over time up it to there possibly but I don't want to go any further than 300bhp
Russ
Old 04-07-2013, 11:39 AM
  #42
rsmark86
rsmark86's Avatar
Originally Posted by crazycage
spare engine built for £150?
Ib5 box !
Old 04-07-2013, 11:44 AM
  #43
rsmark86
rsmark86's Avatar
Russ
Black top inlet bolts straight on, just make up a charge pipe, a stage 3 t3 will give you the 260+bhp your after and have more response and the vxr injectors will be fine
Old 04-07-2013, 01:05 PM
  #44
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah that was a good deal mate!
As Mark says above.
Old 04-07-2013, 01:20 PM
  #45
rsmark86
rsmark86's Avatar
Got shed loads to do though before its ready and still need a turbo, a friend of mine might be giving me a standard turbo to send off for a rebuilt, stage 3 upgrade, that way I will have a fresh turbo
robnock
21
13-05-2019 05:29 PM
robnock
22-08-2015 10:51 AM
Chopshop85
17-08-2015 06:38 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Zetec turbo help/advise
