Sierra brakes question
Hi peeps. Just wondering sumthin.
Ive got a sapphire glx on a k plate and i wana know if 2wd cossie 4 pots would bolt straight on? If not what would i need to do??
Any help would be very much apreciated
Ah cool. Easy fix then . Cheers for the advise. I need to het it done pronto cos my saph has horrific brake judder and i wana do full cossied rep over time so i wana try and do some unpgrades along the way during general maintenence. Ive got loadsa pics snd ill do a thread soon just abot embarassed about this one atm lol
Normal Sierra disks are 240/260mm, 2WD cos are 283, so a fair difference.
You can just fit the cossie hubs to the rear. For the fronts the calipers bolt the other way round. Instead of the pad carrier being threaded like it is on a normal sierra you need to tap the hub for the 2wd calipers to bolt too.
Resident Wrestling Legend
Mondeo callers
St170 focus discs
Job done
Just need to drill the hole in the hub out
Simplest method to big brakes without the need to pay Cossie tax on the calipers (I've got some in t garage if you need dimensions and measurements if you have the heart set on the Cossie conversion, hubs as well, but don't forget you'll need the Cossie tcas as well)
St170 focus discs
Job done
Hi peeps. Baisicly i want the 2wd four pots on the front with braided lines and tbh i thought the rear brakes were the same but if there not ill convert the rears too. The 4x4 rears are vented arnt they? Can i fit them if i just change the hubs?
You'll need cossie bearing carriers, or if you're good with a welder, you can modify the standard ones. You will also need 4x4 caliper carriers - they allow for the thicker discs - caliper is exactly the same.
Ah cool well if you have any bits for sale ill buy it all in july. Brakes badly needed
I am a confident welder but dot really fancy welding something that holds my brakes on lol
So my oarts list should be,
2wd 4 pot calipers
2wd discs
2wd cossie braided hose set
4wd bearing carriers
4wd calipers and carriers
4wd rear discs
Is that all i need yea???
2wd 4 pot calipers
2wd discs
4wd rear discs
