Would it be difficult to fit twin 40's to an rs 16i?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Not very but why? You'd need a cvh inlet manifold. The carbs and bracketry for the throttle cable. Some kind of fuel pressure regulator to bring down the pressure to about 5psi if i remember right and a good set up
Id save the 16i engine for a rainy day or for a collector and if you're desparate for more power or ditching the ignition the go for a zetec on webber throttle bodies and the webber ecu, you can get it all as a kit to bolt on with a decent base map, no bother
