can you measure pipe thickness with tape measure?
hi i need to order some new water pipes for my car. however i dont know there size.
i dont have a micrometer to measure what sizes i need can i use a tape measure if so do i just measure around the pipe or measure the end of the pipe across ?
thanks
thanks
Weeeeeeeeeeeeeeeeeeee
To get outer diameter, measure around the circumference and divide by Pi.
If you know the thickness of the pipe wall, you could work out the inner diameter by subtracting 2x the thickness.
Just measure straight across the outside diameter (O.D.) of the metal pipes, thats what size internal diameter (I.D.) silicone pipes. You will need.
Ben
Edit to say, put the tape on 100mm mark, more accurate than the metal piece on the end.
07-10-2015 12:56 PM
