Who knows how to fix clios?
Starts fine and then, when its warm, won't fire up
Once you've got it going if its cold it carets on until you switch off and sometimes it just dies after a few minutes of use
Pluged the code reader in and it's showing 0136 code, the O2 sensor apparently according to the Internet
Anyone help?
Trawling the Internet comes up with a possible dirty inlet as well but I don't want to buy a sensor and it not cure the fault so what else could it be?
I'd ask chip or mike but I'm not sure they are clued up on clios as a rule or just the fast ones
Anyone help?
renault dealer?!
(sorry couldnt help myself )
try disconnecting the sensor and see if itll run without it? i know the older zetecs will run fine without it connect, presumably on a preset map stored on the ecu?! worth a try anyway. obviously it throw up a check engine light or whatever if it has one, but if the car will run and drive while hot itll confirm its that which is the problem. i would have sugested coolant temp sensor otherwise, just the obvious one really.
Just get the owner to call out one of these home start places, let them diagnose it for free
Just my modest t'penceworth, if youre saying its now not starting from cold, O2 sensors dont generally kick into action until the engine is warm, because the engine needs a rich mixture when cold. In my experience cant recall a duff O2 sensor ever stopping a car from starting!
As already said, a crank sensor can though. Theyre a piece of piss to fit and cost about a tenner or something from somewhere like euro car parts. Its well worth just chucking one at it!
Testing the future
there should be no need to just chuck parts at a modern car - they have sophisticated On Board Diagnostics to tell you what is wrong if you have the proper equipment. If it was a faulty crank sensor, surely that fault would be logged?
You're right in theory mate and I agree with you, but in my 12 years I've found that french shit seems to defy all reason, and everything that college, university and various diagnostic courses have taught me!!
Yes a faulty crank sensor may log a permanent fault code, it may even have logged one in 'pending codes', (detected during last drive) but annoyingly that's not always the case.
a tenner on a crank sensor is a cheap and cheerful fix, if it fixes the fault
that said, it won't fire up now, just cranks over and the fuel pump works so i'll tell him to get one of them and see what happens when he decides i'm available to fit it
I had a clio once and one day it wouldn't start for me after I'd parked up for 5 mins, it ended up being the throttle body. Might get away with cleaning it all out but I had to replace mine.
Pull off a plug lead and crank the car to check for a spark. if you don't have one then its down to the crank sensor mate. If you do have a spark then i would be looking at the ECU because they sit on the back of the inlet and over time the heat gets to them and they short out chucking codes up that have nothing to do with the problem. Over the last few yrs i have seen this happen alot with the ecu and thats why most just send the car to the crusher.
yeah as said it wont be the lambda if its not starting from cold.
as above check for spark, if there is spark, it sounds daft but have you tried holding the throotle partly open while you crank it. if the ecu sees the tps at say 50% itll attempt to start the car under diffrent parameters i guess you could say, ive had a few cars with weird hot/cold starting faults and this never fails to get them going after a few seconds.
touch the crank sensor and see if it starts.have this quite alot when get a non start renault.cranks but wont fire due to the crank sensor building up resistance so ecu cant see a signal for spark.by touching it your grounding it causing resistance to go.
Russ Payne
25-09-2015 08:29 PM
Cos500
16-09-2015 09:50 PM
andrewmctiernan
08-09-2015 03:05 PM
