can a actuator be TOO STRONG!!!??????
i have a -34 on my t34 (saph cosworth) ....... but it will almost boost cut when im @ 4300-4500 then recover and carry on ...... if i ease the power in it doesnt seem to happen?????
Someone told me the actuator may be "too strong" is this possible or do i really need a -31??
what boost are you running (peak + held) and what preload do you have. what other method of boost control do you use? (bleedvalve, amalvalve, air-air, dawes, boost controller etc. etc.)
amalvalve, 22/23psi holding peaking 24psi ish (going by gauge) T34, greens, bd10 inlet ...... replaced map sensor things like that ...... what could be wrong with it .... only just run in.... when it gets to 4300 ish almost like a boost cut?? but then picks up straight afterwards and carrys on to red line
the actuator was jetted for a t3 on stage 1 using the -34 ......... i have now got the same amal valve, same -34 just i run a t34 now instead of the t3???? would that effect it??
