2nd attempted theft of my RS!
#41
problem is any thief can view a website like this and see everything they need to know in great detail and the nicer the car the more of a target your car will be, just reading through someones posts for a while you can find out single or married has a dog or not if their neighbours are busy bodys etc etc you get the drift
#43
Irregular Poster
Statey, its about time you pulled the pics of your fez off the forums. As mentioned, too many lurkers see what goes on and then info gets passed around. Then the next thing your pride and joy is gone!
#44
Balls Deep!
Adjusting the proximity sensor
It is recommended that adjustments be performed away from fluorescent lighting, large metal structures, or confined areas that can affect the sensor field. The alarm will exit adjustment mode automatically 60 seconds after the last adjustment signal from the transmitter and revert to its previous settings.
The proximity sensor field takes one to two minutes to settle after entering adjustment mode, so begin adjusting the sensor within 45 seconds and adjust it slowly so it has time to settle. After two minutes you will have a consistent field during adjustment testing.
Each zone has 32 settings that are indicated by chirps that raise and lower in frequency as adjustments are made. Total adjustment time for this sensor should be five minutes or less.
Note: You MUST exit using the ARM/DISARM button after programming
to lock in the new settings!
Read the following instructions thoroughly for a full understanding of how to properly adjust this sensor:
1. Disarm system
2. Transmit Channel 16. (Press cliff 3 times then *1 time)
. The LED will turn on and the siren will chirp 1 time.
. Primary (full trigger) zone adjustment has now been entered.
. Primary zone can now be adjusted.
3. Adjusting Primary Zone
. Press (trunk) of the remote control to increase sensitivity.
. Press (*) of the remote control to decrease sensitivity.
. The sensor Primary zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated.
4. Press (**) to adjust Warn-Away zone
. Siren chirps 1 time.
. Warn-away Zone adjustment has now been entered.
. Warn-away Zone can now be adjusted.
5. Adjust Warn-away Zone
. Press (trunk)to increase sensitivity.
. Press (*)to decrease sensitivity.
. The sensor Warn-away zone can be tested at any time during adjustment and will generate 1 siren chirp each time the zone is activated.
6. Press (lock/unlock) of the remote control to return to Primary zone adjustment and lock in Warn Away zone setting.
. Siren chirps 2 times
. Primary zone can now be re-adjusted as described in step 3.
. Or press (lock/unlock) again to lock in primary zone setting and exit programming mode.
. The siren will chirp 3 times when sensor adjustment mode has been exited.
. Auto-Scroll for adjusting sensitivity - press and hold (trunk) or (*) to increase or decrease sensitivity setting several levels rapidly.
1. Disarm system
07-10-2015 12:56 PM
rog
04-09-2015 07:24 AM
