Cosworths FFS - SORTED!!
Just been out to the car to fit the ECU and 403's. This is after getting a chip from MSD - 380bhp jobbie.
So, ECU fitted along with 403's, hit the start button and whoooph she fired up - ON 3 FOOKIN CYLINDERS
Soooooo pi55ed off. Everytime I have good intention and look forward to doing something on the car there is always something that goes wrong. It really makes me sick.
It is not firing on number one cylinder. If I remove the injector plug it stays the same - if I remove the other 3 it worsens. I just shut the bonnet and walked away
It could have been so easy but yet again I have another issue to track down and deal with. I know I have to check for power at the injector plug, maybe swap the injector to rule that out and then swap out the ecu for a known good one incase there is an issue with that. Couldn't be arsed tonight - really had enough.
Will not get rid, sell or break but by christ do they try your patience.
Thanks for listening
Swap the injector with another cylinder see if it moves the problem with it if it does try tapping the injector with a spanner. The ball might be stuck.
Yes lads, second hand 403's. Got them in good faith and working from MT-Motorsport so I guess they were working well when he broke the car.
Do they suffer?
I will go out and have a swap about but I walked away - it saves having to fit a windscreen too
Do they suffer?
Will have a swap about tomoz.
On 071's too - will whip em out and see whats going on - was running fine on stage 3 - chip one minute and 403's and no 1 down the next.
I do think its a sticky injector as the ecu wouldn't mess about on just one cylinder would it?
Will check the main ecu plug too - never had issues but process of elimination.
So, with the engine running I guess I set my multimeter to 12v but what reading should I be getting. I know its initially 12v to fire injectors but hold open is lower. Will the speed of the cycles not be detected therefore just see a constant 12v at the meter?
The injectors have a permanent feed.
The ECU's switches the earth, it would be very crude to use a multimeter and the pulses will most likely be to fast to capture. Really you should use NOID lights.
Of course you don't actually know the fueling is wrong, what makes you think it isn't ignition related, if it were me I would start with the basics, i.e. examining the plug(s) etc.
Martin
Martin
lost now lol - i just want to know if something electrical is present at the injector connector with it off the injector itself with the engine running.
i dont want to know cycle or duration - just if it is getting something.........
Not interested in fueling at the moment - to have fuel would be good lol
If you tried using a meter, the pulsing is probably to fast for your meter to register.
Martin
Yes, and as I say, you can't really, you can check whether there is power there by using another grounding point, but then this doesn't tell you whether the ground/ECU side is ok, hence why you need NOID lights really.
Martin
Martin
Has a large member
If you want to see if that injector plug has power then just get an amber side repeater bulb off an old ford (sierra one possibly) and its a direct plug in. if the light pulses then your all good.
ive got one i use but cant remember what ford it was off as some are different.
Martin
competant bodger
could very well be sooted up plugs then mate, mine is in storage at my garage now mate and gets driven in and out every day and soots up the plugs to the point of missfiring once every two weeks or so they dont like idling even more so when the fuelling is out slightly, whip the plugs out give em a wire brush and pop em back in
did u put the leads back in wrong order? Then check plugs, then injectors.
Mine was in storage for 5years without starting once. We had dizzy rotor replaced, checked power to injectors. Still wouldnt start up UNTILL we dropped an injector on the rocker cover and then the fucker started again!lol so give them a gentle tap
Well, update time........... just been out and had the fuel rail off and swapped 1 & 4 injectors over. Started her up and nothing on number 4 and so issue has moved cylinder. Number 1 cylinder now worsens if the injector is unplugged. The fault is with one of my 403's. I did give them a tap before replacing them and to see if any crud came out but were clean.
ANYONE GOT A SPARE 403 PLEASE?
Live long and prosper!!
hope you find another injector or he can replace it for you.
Regards
Paul
It does click as I have had them out on the bench but it is a different and weaker click to the others. I have tried tapping it to varying degrees but no such luck.
So, no point in cleaning a duff injector really. Looking out for a replacement. Shame really - especially if it had been my every day car.
Fair comment are you running that chip with closed loop? on my set up i'm getting 33mpg off boost. Ive tried greys before and just found they inject soo much fuel at idle making the engine sound nasty only my opinion of course
Regards
Paul
Regards
Paul
1 Post
Have you tried other plugs yet? For the sake of only £10 a set, it's good to have a spare set.
This doesn't really say anything about the injector as when you disconnect it it's noticable that it was pulsing and providing fuel, it could still be your plugs. The 071C's are great plugs, but once they get sooted up or any kind of contaminent, then it's very hard to get them to work to original standard regardless of the usual burning the tip etc.
I am happy that its not injector wiring, connectors, ecu, plugs etc.
1 Post
Ah sorry, must have read that wrong, though you said it didn't move. Ah well, still buy new plugs as spares And get those injectors to Jimbo for flow testing and cleaning
I have spoken to Mark but if he aint got any thats no good. I may have a lead with Jimbo as posted earlier.
I will start to have a ring round next week. I am not desperate, more of an inconvenience I guess.
I am deffo not buying a new set I will rip it all out and go back to greens lol
