Carb'd zetec!
Carb'd zetec!
Lookin into running bike carbs on a zetec 1.8 engine what are best to use, does the cc of the bike matter, can you use 600/750 carbs or is it better to just go straight for the 1000cc carbs?!
Thanks in advance!
Thanks in advance!
An eye for detail...
I went for bike injector bodies for my 1.8
I thought a good way to start was go similar to the kits available. And not too much bigger than the ports etc. good taper and length means you can use smaller bodies.
I got some 07 cbr1000rr bodies which suit 1.8 blacktop sizing, cause they were cheap enough. Measure your ports and do a bit of reading on throttle body sizing, and you'll know what size to look for. You'll probably find the bike body sizes out quite easily. Keep the runners long as possible and you'll have a nice amount of torque.
im running a 2.0 zetec on 600cc bike carbs from in a ninja in my mk2 escort...
Like said just figure out the size of the ports and match them as best as you can
http://www.jenvey.co.uk/jenvey/throt...envey-dynamics
That link will help get you on the right path. Anything will work, but that'll help you make it work to its best.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
