EGR Valve Focus Tdci?
burning oil
Mine is at the back on my 2004 tdci and its part of the manifold so not easy to clean. I pulled the vac hose of the top of mine as soon as I bought the car so it didn't get chance give me any agro
burning oil
Mines the old 1.8 115bhp lynx engine thats why its at the back. Im presuming saphcosmikes is the same if he has a mk1.5 tdci sport the same as me. I think the 2.0 was fitted to the mk 2's
Received 1,044 Likes
Yeh its bolts to the inlet.manifold.Its an easy job to remove to clean out. there are a few torx bits that hold it to the nanifold and a small L shaped bracket that is bolted to the valve motor.
burning oil
When I bought my focus it had a flat spot. All I did was clean out the inlet and egr best I could with a huge can of carb cleaner a rag and a big flat blade screwdriver. I cleaned loads of thick crap out. After I pulled the vacumn hose of the top so the egr valve stays shut and just popped a bolt in the hose.
The car run so much better after and has improved more over time. That was a year and half ago.
burning oil
Smoke out the back, poor running , lack of power, management light on. Loads of things really. If you ask me they are a waste of time. Majority of older diesels end up with them blocked then drive round with clouds of smoke coming out the back while returning shite mpg.
Now how is that supposed to better to the environment. it's yet another crap device to cause unreliabilty and cost to motoring.
