Cosworth ECU / loom plug - Pin identification?
#42
would try the relay first as i was going to suggest that.
Could it be something to do with your alarm?
Have you check continuity of the wire for breaks?
#43
cheers Simon
perhaps you could give me some help with:-
a cossie ECU plug - i need one for a project
what sort of wire is suitable for an engine loom
#44
The ecu plugs are like rocking horse sh*t at the moment.
Even my normal supllier has had problems.
Got a batch of 50 comming in about 5-10 days. Best I can do at the moment.
As for wire, I dont have tech info to hand as I am at home !
I think grade 16x0.2mm is suitable for all connections except the grounds (pins 1+19)
which need to be doubled up as these provide power to ALL the system.
#48
SapphyMike,
The current normal retail price is £500
The whole SECS business is being reviewed as I am in the process of selling the a
large part of my business to another company.
This price will fall as a result due to the extra manufacturing capacity I will have
and to give the product a kick start under a new name !
(existing orders will be adjusted to reflect this price)
My advice, is wait for the public announcment i shall make later in the week
for further information once I have signed on the dotted line.
GARETH T, Thanks
GARETH T, Thanks
#49
ryan, what relay feeds the ecu? i can only source the wire for pin 20 back to behinf the transmission tunnel.. then i lose it so i cant track where it ends up
why is nothing easy!
#66
Originally Posted by SECS
Pin 20 is the second pin along in the row with least pins
and is near where the cable enters the plug.
hope that helps
hope that helps
As Dingy said, dont rely on colours. Could have been rewired due to
previous faults or alarm installation.
ekjim
17-08-2015 08:57 PM
