Head gasket question
Old Oct 21, 2011 | 11:56 AM
mk2rstaff's Avatar
mk2rstaff
Default Head gasket question
For instance if my head was skimmed to much and i needed a thick gasket to compensate for the lack of gap lets say, would i be able to use 2 multi layer steel ones or best just 1 thick one??? anyone tried this or think i am a *&^%$"£*& moron lol.
Old Oct 21, 2011 | 01:10 PM
axelriet's Avatar
axelriet
1 thick. Top and bottom layers of layered gaskets needs flat surfaces. Gasket to gasket is not likely to work.
Old Oct 21, 2011 | 03:08 PM
the mk1 kid's Avatar
the mk1 kid
If you think about it, the gasket is the weak spot on any engine - having two literally doubles your changes of blowing one/both as you have twice the amount of mating faces.
Tom
Old Oct 21, 2011 | 03:10 PM
chaffe's Avatar
chaffe
Turbocharging Technician
Skim said amount off of pistons? what we speaking? 10-20 thou?
Old Oct 21, 2011 | 03:13 PM
BRAMMER's Avatar
BRAMMER
So what size is the head?
Old Oct 21, 2011 | 03:17 PM
James @ M Developments.'s Avatar
head thickness is also critical for other reasons, i.e. amount of material holding the valve seats in place. if its over skimmed, then its not really ideal to use it without some extensive repair work.
otherwise this can happen
Old Oct 21, 2011 | 04:37 PM
zivt's Avatar
zivt
how was the nos units are supposed to work tell me anyone
Old Oct 21, 2011 | 08:45 PM
Ridgey's Avatar
Ridgey
There was an engineering firm that manufactured thick gaskets or plates, can't remember the name though. They did them for Fords including the YB.
Old Oct 21, 2011 | 09:48 PM
v man's Avatar
v man
Zee Germans are coming
mk motorsport can make a spacer plate
Old Oct 22, 2011 | 06:42 AM
mk2rstaff's Avatar
mk2rstaff
Thanks mate i will give them a bell.
Thanks to all the advice above and i was thinking i was being a *&%£""*( Moron lol.
I am not sure on the exact thickness yet as i am away in Afghan right now, i will post size when i return and see what everyone thinks, iirc 138mm is the standard size i am sure it's been skimmed once, i only really want to keep the head because it has has some light port and polish wok done, i will see thanks again chaps.
Old Oct 22, 2011 | 07:27 AM
graham c's Avatar
graham c
you can get the valve seat re-cut that would be better
Old Oct 22, 2011 | 08:07 AM
BRAMMER's Avatar
BRAMMER
I think some if not all were 139 new and you have a few skims on them so if it's std and only had one skim then it's fine - if the copper ring on the underside is flush with the alloy then it's had a few skims if not and still sunken then your still fine but still measure it (although some will exceed this with no issues) but you will be told the head is scrap.
Old Nov 7, 2011 | 01:25 PM
mk2rstaff's Avatar
mk2rstaff
I will try and get some pics when i manage to get round the shop, hopefully tomorrow sometime, i can make decisions on how to proceed after that, thank guys.
Old Nov 7, 2011 | 01:32 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i wouldent use a spacer plate or too gaskets just have the amount taken off the pistons if there is a clearance issue much more reliable way of doing it!
Old Nov 8, 2011 | 05:22 PM
mk2rstaff's Avatar
mk2rstaff
Ok slight update, stripped and cleaned it today (well as much as i could) before any work has been done on the head and block i have noticed that the valves are already ever so slighty touching the pistons, that was with a 12 yr old gpa gasket, does anyone know the thickness of these compared to the 5 layer multi gasket, when they say 2.00mm is that the compressed thickness that they will be after fitment or starting thickness???
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
