Anyone used Microsquirt?
Dreamer
as above,
talking about the fully built Unit, Microsquirt, not to be confused with megasquirt..
any opinions welcome..
http://www.microsquirt.info/
cheers
JOSH
cheers
JOSH
Dreamer
injection and ignition mate, has 2 injector drivers that can each run 1 low impedence or 4 high impedence injecters per driver.
so can run up to a v8 (not idealy) or can run batch injection on a 4 cylinder and ford EDIS wasted spark ignition.
can run boosted engines with suitible map sensor.
just like the look of it for me running a N/A 1.8 16v in my nova, possibly on TB's
Dreamer
It can run a v6 ok, just using batch injection, by firing 3 of the 6 injectors at a time. not ideal but it would run fine.
if i was running anything bigger than a 4 cylinder or a boosted setup, i would look at full megasquirt for the extra features and injector drivers IMO
id like full megasquirt but i also like the fact that this is fully programable injection and ignition for Ł299 with unterminated loom and USB connection.
Its Broken.....
Dreamer
Here you go, megasquirt all the way, for the sake of Ł150, you can have the all seinging all dancing ecu fully assembled. But thats just my opinion, each to their own
http://www.diyautotune.com/
stucapri2.9iTT
09-02-2012 09:40 PM
mobb-black
03-08-2011 10:01 AM
