Spun a big end bearing!
Old 15-08-2011, 04:22 PM
  #81
Canada1
Canada1's Avatar
Originally Posted by Karlos G
What you must remember Perry is that no 270bhp 1.6L RST makes anywhere near peek torque in 1st or 2nd as the turbo barely has time to spool, there is of course some wheelspin in the dry at high RPM's but not much really. Your 3.4L NA will be making much more torque than any RST does in those gears! lol
Wow!
I had no idea that turbo lag time was enough that no boost would be present in first or second gear. You would only have the 270 hp in 3rd or 4th gear?
I have driven the old (1987) 2.3 turbo mustangs here, and full boost was available
below 3000 rpm. One could feel the boost "hit" in first and second gear.
These 2.3's had the .63 exhaust turbine as well.
The 911 did have a 915 gearbox with factory Porsche limited slip.
Old 15-08-2011, 04:40 PM
  #82
Karlos G
Balls Deep!
Karlos G's Avatar
We do make boost I didnt mean we literally make none!! lol
But certainly no where near peek power/torque and if we do it will be very late in the RPM range....
This of course will vary greatly depending on your manifolds, gear ratio's, wheel size, boost control method, C/R, etc.. So is a bit of a sweeping statement!
Old 15-08-2011, 05:50 PM
  #83
Canada1
Canada1's Avatar
Thanks for the info Karlos.
I always assumed that the high power turbo cvh's had more torque than HP.
The 3.4 Porsche had 230 lb ft torque(at 5000 rpm) and 280 hp (at 7,000 rpm)
The 1970 911 was very light (2300 lbs)
I assume the UK Escorts are close to this weight too?
You must get considerable wheelspin after the boost pressure builds in 1st or second?
Are you running soft compund slicks?
Old 15-08-2011, 06:00 PM
  #84
crazycage
crazycage's Avatar
Originally Posted by Canada1
How much power is really useable in a front drive Escort?
I would think anything near a real 250 HP would be all but useless in the first 2 or 3 gears anyhow.
I can understand rear drive - or 4 wheel drive using 300, 400 or 500+hp.
enlighten me.
i have no problem putting my power down in dry conditions.
Old 15-08-2011, 06:27 PM
  #85
Rob_DOHC
Rob_DOHC's Avatar
Mine had 205 ft.lbs so i guess if Karlos was close to 270 bhp i would expect him to have had over 250 ft.lbs... The escort weights 940kg's i think (2072 lbs).
Whats the geometry of a 70's porsche like? all the pics i can find show loads of negative camber etc....
Old 15-08-2011, 06:56 PM
  #86
Rick
Rick's Avatar
Re the gasket issues,
It's more when running 20psi or over. I have the time and money to mess about as the RS is just a toy. If I wanted a reliable no messing engine then I would use the blacktop, it's properly solid. I said in my other post, you are introducing extra complications and you're not actually gaining anything in real terms.
VVT: locking the cam is what I've been doing for years now, but it gives horrid idle, and poor fuel consumption at low speeds. The engine also has much less torque off boost than the equivalent blacktop. With MS3, you will need the MS3 daughter board, the MS3X expander board and a new loom, so add all that in. The code isn't ready yet either! I have a Focus ST170 sat outside that I'm working on at the moment.
MS2 cannot control it properly. It is NOT and on/off system - doing like this gives shit results! You can't do it with open loom PWM either. It needs a dedicated control loop as the PWM is not related to cam position, but how fast the cam is moves.
Rick
Old 15-08-2011, 07:02 PM
  #87
Rob_DOHC
Rob_DOHC's Avatar
That throws that out the window then lol shame the duty doesn't relate to cam position as that would have been pretty simples...
Rob,
Old 15-08-2011, 08:11 PM
  #88
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i'm only about 250bhp and with the FRS box i don't really suffer wheelspin too badly on T1r's, when i get the boost up from 9psi to 14.5 then i should be around 330bhp is, going off a slightly lower spec of engine than mine.
power figures are estimates/based of similar specs/results.
the viscous diff from an rst is poor at putting power down compared with an ATB diff, although if you lift a wheel on the rst it will keep pulling, whereas the ATB will not till both wheels are grounded.
that's my 2p worth anyway.
sean
Old 15-08-2011, 08:35 PM
  #89
Karlos G
Balls Deep!
Karlos G's Avatar
Rick
I think what I'll do for now then is run a blacktop head, I'll still have the ST head for if I fancy it in the future and MS3 is ready.
So I use the springs from the ST head into the blacktop is that right, did someone mention I need shims or spacers or something too?
Thanks for your help Rick!
Old 15-08-2011, 08:37 PM
  #90
rhinopower
rhinopower's Avatar
I've got a set of st170 springs if you don't want to strip the head?
Old 15-08-2011, 09:50 PM
  #91
Rick
Rick's Avatar
ST Springs are shorter, yes. I can't remember what size shimms you need for a blacktop, Gary might know though.
Rick
Old 16-08-2011, 11:34 AM
  #92
Rogeyboy
Rogeyboy's Avatar
What would the advantage of using the vvt be then? Shame MS can't control it, that'd be pretty cool.
A diff upgrade certainly helps put the power down...
Old 16-08-2011, 02:44 PM
  #93
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
the advantages are being able to alter the cam timing to give better economy and smooth driving and much better performance when needed. adjusting the valve timing and overlap can really pull a lot of power out of an engine with no compromises. without it we're all stuck with crappy idles or lower top end power.
Old 17-08-2011, 06:59 AM
  #94
Rogeyboy
Rogeyboy's Avatar
Oh ic hence y the manufacturers love it, for the economy side - altho the ST170 is awful on fuel... But ppl like us can harness the extra power it frees up!
Old 17-08-2011, 11:40 AM
  #95
Rob_DOHC
Rob_DOHC's Avatar
Extra power, etc, I think manufacturers do it for better emissions too.
The new BMW vanos is pretty amazing. It adjusts cam timing and valve lift, their new cars don't even have a throttle butterfly.
Rob,
Old 17-08-2011, 11:50 AM
  #96
chaffe
Turbocharging Technician
chaffe's Avatar
just what you want second hand out of warranty
Old 17-08-2011, 12:00 PM
  #97
Rob_DOHC
Rob_DOHC's Avatar
Yea, nice and simple to fix
Old 17-08-2011, 04:28 PM
  #98
Rogeyboy
Rogeyboy's Avatar
Tell me about it, i've been looking at buying an E39 M5 and they r reknowned for vanos issues totalling over 2k to fix! The price of them is tumbling fast atm tho, so in the near future will be the time to purchase...
Anyway back on topic..!
Old 17-08-2011, 04:48 PM
  #99
Rob_DOHC
Rob_DOHC's Avatar
Good stuff, ignoring problems they are supposed to be an awesome car. Looked at a few m3's a while ago (which also suffer with vanos issues lol) and thought they would make an epic every day car.
Old 17-08-2011, 04:54 PM
  #100
Karlos G
Balls Deep!
Karlos G's Avatar
Been thinking more about the cause of my spun bearing and I think it was air pocketing in the oil...
I noticed a while ago that when at sustained high rpm (6K+) on the motorway my oil pressure was dropping from 60psi (or whatever it was, cant remember exactly) down to about 20psi then back up again in a on/off fashion, after checking my oil level it was at half way on the dipstick, I topped it up and never experienced the problem again... I think the oil was taking too long to drain back down to the sump at high RPM's and anything below half way was not enough to buffer this and the pickup pipe was taking gulps of air, this of course would be pumped around the engine and potentially allow the bearing to contact the journal for a split second.
Old 17-08-2011, 05:46 PM
  #101
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
well the zetec has more oil ways back down to the block (double) so that should help.
may be worth sorting out big wings onto the sump though, metal sump lower should be easy to weld an extra bit to.
interesting idea on the air pockets though, dead possible.
Old 17-08-2011, 05:50 PM
  #102
crazycage
crazycage's Avatar
no need on the blacktop sump mate.
Old 17-08-2011, 06:16 PM
  #103
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i know it doesn't need it, but always an option at a later date if you ever push it hard enough round corners under full throttle.
Old 17-08-2011, 06:56 PM
  #104
matthart
matthart's Avatar
You're not filling me with joy about the state of your oil pump :-P
  #105
Karlos G
Balls Deep!
Karlos G's Avatar
hahaha read the rest of the post!
Old 17-08-2011, 07:01 PM
  #106
matthart
matthart's Avatar
Does sound like oil starvation I'll admit
Old 17-08-2011, 10:18 PM
  #107
Rob_DOHC
Rob_DOHC's Avatar
No oil pressure will do it every time
Rob,
Old 18-08-2011, 10:02 AM
  #108
Rogeyboy
Rogeyboy's Avatar
Thats an interesting theory... Never really thought about that, makes perfect sense tho!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
turbotrev
14
27-09-2015 10:44 AM
rsstav
07-09-2015 04:43 AM
Quick Reply: Spun a big end bearing!
