bodywork bods.....
Boost Builder
bodywork bods.....
what is the correct way to remove wings ?????? same for fitting new.... need to take some off to do some welding before new ones fitting
i dont know what car you drive but i bought a spot weld drill bit from machine mark (approx £4) and drilled out the spots along the topedge of the wing and removed the 10mm bolt, then drille dout the spot welds along down the a pillar, this let me bend the wing out enought to drill out the ones that join it to the front panel. about a 15min job max.
rsguy
44
29-09-2015 03:29 PM
