Ford s max leaking water ant ideas
Pulled back the frond pass, side mat to find a very wet carpet soaked it up and 3 days latter its worse,it has rained once for a hour could it be the air con leaking the drivers side is bone dry. It has not rainned enough for it to be that wet .
Does your bonnet open from the inside if so try the rubber grommit some times it comes out windscreen wipers to engine malfunctions. One fault causes the battery to drain in a couple of days if the car is not used, leaving owners stranded.
The fit and finish of the trim appears to be an issue, too, with items working loose or breaking over time. The centre console and door trims seem particularly vulnerable, and the interior can look scruffy quickly if it's not looked after.
Some cars suffer mysterious steering 'clonks', especially at low speed. Dealers can fix it, but the problem has a habit of reappearing.
So far, there have been a few recalls that concern the S-Max, but the most important cover overly stiff brake pedals and diesel engines cutting out. Cars should have been recalled to address these, but get a franchised dealer to confirm that any model you're looking at has been called back.
