Crackle black paint! Help!
Basically, I know its getting old hat now, but I'd still like to do some crackle black in my engine bay. (I'm not keen on chrome and stuff really)
Soooo the question is pretty simple really.
What can I use it on? I know people do header tanks and stuff, but is it designed for metal? I have a fair few bits made in plastic that I'd like to cover, just to change it from the norm.
Also, how do you use it? Does it need heat treating to make it crackle?
ive done loads of metal bits in my cossie bay, rocker cover, header tank etc. I found it crackled better when heated. Same on a couple of plastic bits ive recently done. Although obviously dont heat that too much as it well melt/distort.
Also i wouldnt say its getting old hat you don't see that many doing it.
I've done a few bit's on various car all metal though, the key is to get the item as warm as poss (within reason of course) and then follow the spray instructions on the tin and leave under heat.
You could well use a heat gun as i would say it should work pretty well, as would your oven in the kitchen - i used the oven in the bookshop and the outcome was pretty good but the 1/2 tin i used was actually 4 years old so maybe a fresher paint and the out come would have been far better
Doing plastic imo is going to be tricky to get the best of finishes, not impossible as long as the room is warm which isn't too hard this time of year or out in the sun light.
try something plastic thats scrap/ non important first as you wouldn't want to fuck everything up
The finish
Hycote wrinkle is glossy and thick but was done in the winter so wasn't the hottest room
http://cgi.ebay.co.uk/Hycote-Wrinkle...item4399d3410f
PJ1 wrinkle paint is more satin which is the look i prefer
http://cgi.ebay.co.uk/PJ1-BLACK-WRIN...item5adbf3dd70
The finish
Thanks brammer. A big help! Throw some more pics of the car up! got a bay shot?
PJ1 looks to be the one I'm going to go for. Prefer the look. Shiny crackle must be an arse to clean!
Time to drag up an oldie!
Do ally Header-tanks get too hot for Crackle paint? (Bailey style) The PJ1 that Brammer suggested says it'll withstand 177 degree's, but unsure as to how hot headertanks get? I know they're FOOKIN hot!
Any ideas?
Any ideas?
Dreamer
most parts of the coolant system wont see above 80-90*C
