Smokey diesel
Smokey diesel
Can someone help I've got 2008 diesel van done about 48k miles when I'm accelarating along the road there is always big pluff of black smoke is this normal I know old diesels do it but didn't expect it from a new dieselS
is it holding back on power at all?
if it is and then a big surge of power its at a guess the egr,could be an injector problem also. a split intercooler pipe will cause this but a sucking noise will always be heard.
[QUOTE=iamrab;5506580]is it holding back on power at all?
if it is and then a big surge of power its at a guess the egr,could be an injector problem also. a split intercooler pipe will cause this but a sucking noise will always be heard.[/it drives ok it just seems to be alot of smoke when accelerating under pressure like hills
Received 1,044 Likes
I would check to see if the air filter is clean. If a intercooler pipe is split you should here a whossing noise when your flooring the van you should have a lack of power too.
Another thing is I've not long had a new turbo fitted and I've pulled off the intercooler pipe a couple of times now and oil has always come out pipe making a little puddle of oil on ground the intercooler been steam cleaned aswell
