help!!! citroen c2 fault
please can anyone help my girl friends crappy car, it starts and idles but as soon as you touch the gas it starts missing and dies?
its an 07 plate 1.1, tried a coil pack made no difference, anyone?
motorised throttle body pal. do loads of them
also do lots of injectors, check they are sitting right and the o rings arent perished, water drops down from the screenwash nozzles and sits there oxidising so the injectors dont sit right
if thats the case, ask for the modified screenwash nozzles aswell as the injectors
That garage were it is hav said they think it might be a throttle body but I wasn't sure. So is it a common problem with the throttle body? Are they simple to change or best left to pros?
Irregular Poster
Afaik them C2s are all flyby-wire. The throttle pedal sensor could be fucked or maybe an idle control valve. 3 of the 4 saxo vts' i have/had, all had the icv problem!!
Typical french shite. But still love them
garage have given up now, changed, crank sensor, coil pack, throttle body.
im going to go down latter tonight a do a thing i have read called a power latch, it completely erases all faults and so the car has to re learn every thing. read it can help with faults like this
My son has one of these, the GT.
His had very similar problems and he told me that it was eventually traced to a faulty plug on the MAF sensor.
He said that it was not seated properly and had starting problems, cutting out and was using quite a lot of fuel.
It's not missed a beat since replacing the plug.
HTH
Shany
HTH
Shany
after looking, they dont have a MAF sensor its a MAP sensor. i changed it no difference.
i runs and idles but just will not rev, it just misses. its going to have to go to citreon tommorrow. but i realy hope that it catches fire tonight!
i had exactly same problem
its your fuel sender/ pump if you have limeted power when you throttle mine was because one small clip had broken off the pump. there is a service hatch under the bk pasenger side seat good luck pal
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
DixieTheKid
14-09-2015 09:04 PM
NC53
13-09-2015 03:05 PM
Si B
12-09-2015 06:49 AM
