Roller bearing a T4
#41
i think for responce the best mod that can be done is a good head... mines done by james goldstraw at grace engine developments in twyford berks and hes the nuts with yb heads..... and he even specc'ed the cams to suit the turbo ect ....
#42
come on get with the times. gt3071 job done. or gtx3071 if you want some scope for more power with the same spool.
you've all seen cossierichs thread. even with no headwork its a cracking conversion without a hint of surge. even when loaded up in 5th gear.
come on you know it makes sence!!
#46
I'm not clued up about turbo's at all really, the same as a lot of other people but i don't think you can right off a T4 yet and especially the RB version as some may say go for a RB T4 over a GT3076.
If you want the correct answer ask your tuner
I must be one of the only people in the world that actually likes a bit of lag then a massive kick - it's what a cossie is all about imo
#47
my gt35.... 70a/r front .82 rear makes full boost 100rpm later than my mates t34.63
although i have a fully worked head and cams ect and he has standard... both set up by mad....
the gt series turbos are the nuts.... and the new borg warners are even better... or a gtx30
#52
Steve
#55
Caraholic
However, don't confuse "lag" with "boost threshold" .
