Zetec help
Zetec help
Rebuilt an engine joined the gearbox and filled it but it's dripping every thing on it is tight check about 4times. Where it joins the engine right on the bottom..
It's yellow so it gearbox. There is a drain hole or something at bottom of bell housing it's coming through there. Can't get head round it as everything it tight and all new seals
i had to replace the sump on my focus last week and allpartsautomotive supplied me with elring dirko. its made in germany and has sealed my sump perfectly. both surfaces need to be clean dry and degreased first.
the silicone you want is( RTV silicone sealant ) loads of makes around i paid about 5 pound for mine cos i thought the sump was leaking ,but it was the alloy housing that its bolted to ,cos the sump is in two bits ,look close cos the oil gets blown to where you think the leak is ,mine only started leaking when i took my engine out and put it back in the joint must get disturbed if you sit the engine on the floor when its out ,
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
