CVH WASTEGATE CHATTER
It Wasnt Me!
mine chatters on 7psi on K E-jet SOMETIMES you'll get a lil "whoop" an thats it, but mine chatters a few times cant really hear it on the motorway cos the rest of the car muffles it out, but goin through a street or a tunnel it sounds pretty good for an ERST obv nothing compared to a cossie!!
My KE managed RST chatters. Not loudly like an EFi equipped car but it aint bad at all.
EFI will be on the cards eventually but it seems daft to spend 2k for minimal performance gains
sorry guys as u have noticed im a new member an have only recently got my car iv modded loads of other cars but im new to the erst i got the car as a challenge and it came with little apart from k&n scorpion exhaust a bleed valve dont know if it is chiped or anything but i want to get it up to 200+ bhp any ideas and costs?
Originally Posted by SteveRS1980
the guy i got the car off said he thinks the actuator needs replacing could this have an impact on it?
will do fuck all for the noise!!
and don;t touch that bleedvalve!!!!
Team HOTHOT!
it aint frigging wastegate chatter - its fuckall to do with the wastegate
its high pressure boost air been forced back thru the turbocharger and the compressor blades cut the air and create the twittering turkey noises. - turbo chatter or "stall" as some call it
Mine used to chat like a monkey on coke!
u can get mfi to chatter! u just run booodals of boost as Jase P's S2 used to chatter well!
also depends how u come off the power as DOO's S2 used to chatter if u came off slow!
Paul it can be expensive.
Main things you need are EFI manifold, with injectors etc.
EFI turbo loom and brain.
Good idea to get a totaled FRST and swap the bits over.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
