Goodridge Banjo Fittings?
Can you use Banjo fittings for the inlets and outlets on Master Cylinders??
Oviously the threads will be the same, 3/8UNF.
Can you cash a cheque?
Just make sure the copper sealing washer on the side of the master cylinder has a nice flat surface to ...well...seal against & your banjo bolt isn't so long that it bottoms out.
track.focus'd
12-08-2015 05:53 PM
