zete cquestion need answer ASAP
is the silvertop 1.8 zetec block the same as the 2.0 ?? obviously i no the bores are a differnt size but for instance could a 1.8 be bored to 2.1 like the 2.0 can ?
The 2ltr has under piston oil spray jets but the 1.8ltr doesn't,not strictly true as I believe the fiesta RS1800 engine had them, but the normal 1.8 doesn't.
If you bore the 1.8 to try and get 2.0 or 2.1 you will go into the waterway
Get a 2.0 block to start with
They are cast 2.0 into the block
rsguy
44
29-09-2015 03:29 PM
