rs 2000 4x4
Old 27-02-2011, 07:24 PM
stuart collins
stuart collins's Avatar
Default rs 2000 4x4
any 1 now if the rs2000 transfer box and the mondy 4x4 transfer box are the same or can they be made to fit each other
Old 27-02-2011, 07:39 PM
Received 1,044 Likes on 998 Posts
I would of thought they would of been the same.
RS20004x4
RS20004x4's Avatar
no they are different as fair as i know, check with the guys on www.rs2000-16v.com to be sure, they will be able to help with any info.
Old 27-02-2011, 07:50 PM
Oranoco
Oranoco's Avatar
Same fitment but different torque split
Old 27-02-2011, 09:52 PM
Icurus
Icurus's Avatar
I believe they are slightly different in shape/size and are not a straight swap unfortunately.
Old 28-02-2011, 06:36 AM
stuart collins
not goin on a rs 2000 so just need to no if it will mount and work with the 2k box
Old 28-02-2011, 05:13 PM
Mark_
Mark_'s Avatar
it should mount to the box as the mondeo uses a mtx75 which is the same as the rs2k,
however the mondeo t-box favours the front wheels where as the rs2k t -box is a 40/60 power split so most of the power goes to the rears
Old 28-02-2011, 06:02 PM
©hatter Box
©hatter Box's Avatar
the 4x4 boxs are a load of wank so weak its unreal the mondeo boxs are not the same and will not fit
Old 28-02-2011, 06:36 PM
Mark_
Mark_'s Avatar
they arent aload of wank if treated properly.
most fail due to low oil levels or neglect.
jasons old red 4x4 turbo ran over 300bhp reliably with no issues until the new owner decided to do doughnuts from standstill at full throttle.
I remember your white 4x4 cvh turbo, the t-box went bang not long after you bought it didnt it?
Old 28-02-2011, 09:43 PM
IAN RS2k
IAN RS2k's Avatar
I believe the input & output splines are different the Mondeo transfer box is much bigger and stronger it also puts more power to the front wheels so has less strain on the transfer box & rear diff the Mondeo box came out later than the RS2k box so was a revised design so is the better setup
Ian
Old 28-02-2011, 09:49 PM
©hatter Box
I had two in matter of months at 350 a pop its not worth blow that sort of money at it they cant even take std power of 150bhp my rs 2000 4x4 was running 220bhp so had to get rid of it for that but i say this is was so nice to drive just the box let it down. not long after i sold it the same thing happen again so in my eye its the worse thing about the 4x4 that lets it down
gambo08
04-02-2016 10:49 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Iain Mac
30-09-2015 09:39 PM
little bram
27-09-2015 07:45 AM
Quick Reply: rs 2000 4x4
