UPDATE on Saff
UPDATE on Saff
...well the AP 4pots 330 fronts are on...now with front rear braided hoses...bleeding was a piece of piss as i found i had that easi bleed thing using a spare wheel!!!! The other abs sensor that needed replacing broke just like the other side so had to drill it out again...but the good news is the replacement second hand sensors gave me abs backand pump working fineso no more light and rock hard pedal! Also longer front wheels studs put in......and rallycross incar boost control nearly in just gotta get a length of vacuum pipe to finish then 30psi here i come
Stack 52mm oil pressure gauge to do with the alternator drop bracket.
Oh got a set of secondhand good condition coilovers coming...at £300 i couldnt say no but its a mix...leda fronts and gaz rears should be ok...all DIY
TPM961
15-01-2018 10:50 AM
