cossie operating temp & pressures
Im setting up my defi gauges tomorrow and need to know the ideal running temps and pressures..
I know each cars pressures will be diffent but I need to set warnings for oil pressure and fuel pressure so whats the norm?
Also what operating temps for water & oil?
and whats the safe temp before giving it some? about 80 deg for oil?
Turbocharging Technician
water 88 degrees on almost any car if it has a std thermostat? fuel pressure will change from 2 bar to 4 or 5 depending on load, oil temp will be a little (10 deg) higher than coolant temp, not sure about pressure on your engine
its a pointless alarm as you need a low alarm when the pressure is high in boost, not possible, unless the gauge measures rpm and boost pressure and does a calculation. An AFR gauge is a much more accurate way of seeing if the fuel pressure is substandard
Dubs44
19-09-2015 06:31 AM
