Great bit of engineering and engine building!
#41
*** Sierra RS Custard ***
But yes its certainly possible to get a YB to rev reasonably well.
Anyway, i'm glad we agree argueing is pointless and that the cossie power output it feasible
#42
This is a drag engine, so i assume comparing it to touring car engines as a power cap for that configuration is pretty irrelevant.
Also I would hazarcd a guess it uses something a bit more potent as fuel
It probably only has to last for 9 seconds lol
#43
You do get to a point where more octane rating is no longer useful, especially in situations of naturally low VE such as a high rpm N/A motor.
#44
Well if a race bda/bdx can rev to over 10k and as good as damnit 300bhp then i'm fairly sure another 100bhp can be squeezed with funny fuel and a lot of cash, plus an extra thousand or so rpm. Unless you're suggesting the graph is a fake.
Also dont forget the engine in question is 2.5 litres not 2.0
#45
Increasing the capacity will actually make the engine LESS willing to rev for the same head characteristics, so while im sure its mechanically possible to rev a YB that far with the right parts, im not convinced it will yield significantly more power to do so, and even less so on a 2.5 bottom end.
An extra 30% power which you seem to be considering no big deal actually is a VERY BIG jump considering that the engines we are talking about as a starting point (ie touring cars etc) have had hundreds of thousands of pounds (if not millions in some cases) thrown into them already, im not accusing the graph of being faked deliberately, but I dont personally believe that the engine in question would make that same power on the dynos that I am used to.
#46
Clearly i havent tuned one lol
But the touring car engines are not funny fuel drag engines designed to last 30 seconds, thay have to last three races a day so dont keep banging on about them, you keep mentioning them as a starting point not me.
Seeing as a 40 year old BDX on pump fuel falls 25% short of the magic 400 i'll take a bet that 40 years of technology and innovation with some potent fuel can make that YB do 400 for 30 seconds or so
It's hardly as far fetched as the person i was actually talking to was making out.
#47
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Just as a comparison - i looked into making a 10,000rpm revving Zetec and found a suitable crank that would give safe mean piston speeds. I calculated the displacement of the engine using this crank and even on an 86mm bore the largest I could get it was around 1.55 litre. Torque dropped around 20lb/ft everywhere and power was poor at low engine speeds.
Compared to the 2.2 stroker crank i designed that would safely rev to 8000rpm and give around 15lb/ft more torque through the rev range on a theoretically standard engine, there seemed little point in having to uprate the valvetrain and lubrication system to take those extra 2000rpm.
#48
I dont think very much has changed at all, especially when still using an early 1980s cylinder head as your starting point.
What sort of technological advances specifically are you referring to which you think might help someone of today trying to make that power that werent available to the ford works development department 30 or more years ago?
Its NOT about the fuel quality with N/A engines once you are already onto a decent 100+ RON fuel anyway with the naturally low VE, its far more about the airflow. Its very different to turbo engines, you really do VERY quickly reach a point with N/A engines at high rpm where better fuel fails to make a significant difference any more.
What do you actually think is different about that engine to the BDX's you mention that will allow it to swallow over 30% more air than they did? (in fact its more like 40% TBH if you actually do the maths!)
With engines already tuned to that level 4% is a BIG gain, not 40%
#49
#50
Sorry Chip i never realised touring cars were tuned to ultimate power like drag cars
I was under the impression a yb head would flow more than 400bhp so why is the head a restriction if the engine pumps enough air at that rpm and capacity?
Theres plenty of tech that a 40 year old BDX from a ford works team couldnt have
Theres a lot lighter and stronger pistons for a start such as the mmc ones perfect bore do.
In all probability that engine probably has a taller block, if millington did it years ago i'm sure this guy has realised what engine geometry works.
#51
Touring car engine builds get EVERY bhp that the flow limits they are working to will allow, they dont reign back 1 bhp in the interests of reliability as far as im aware, let alone 100bhp!
In the case of a turbo motor (say 2+ bar of boost), you have 3 bar or more of pressure differential, with N/A you have less than 1 bar of pressure differential.
And further more on a turbo engine you have positive pressure differential for the whole intake stroke, on an N/A engine with 50% VE you have only got a positive differential for half the intake stroke.
12000 rpm
200 revs per second (.05 seconds per rev)
in that time you have to get 1 litre (approx amount of atmospheric pressure air to make 200lbft) into your engine through the heads with less than 1 bar pressure differential peak and with the vast majority of that time spent at a far far lower pressure differential than that.
Why is the neck of a bottle a restriction, because its the part that is hardest to get flow through.
What piece of tech were they missing that would allow 4 oval orifices with only atmospheric pressure behind them to flow an extra 40% more air?
#52
passionford pro
cosworth engine(top end) was designed early 80's so not new technology.bottom end...60's??
maybe bda's can run at 10k....what power do they make??
cosworth head valve size cannot flow enough air N/A to make 416hp,no matter what mods you make to it.
design of the engine will not support the 'claimed' hp no matter what piston /rod combo you give it.
what is the highest n/a 4 cyl that you know of??
the honda engine is a much later/better design also.
its not a drag engine its used for rallys/hillclimb so has to last more than 8 seconds but he does drag in it too......all that power and got beat by other mk11 escorts with 25% less power.
the mods to get to the 2.5 litres it will have an even less chance of hitting 11,500rpm n/a
millington engine is prob the closest you will get to said engine...what power are they making at what revs? and they get a lot of money spent on them.FYI 340bhp@8700 with 243lb ft on the 2.7 version which is totally custom to suit N/A with billet block etc........only another 76 bhp and 2800rpm to find on an already highly tuned race engine.
mccraes millington done 335bhp at 7,750rpm with 235lb.ft at 5,600rpm with no expense spared at the time
#53
http://www.youtube.com/watch?v=ErRier3Ip3w
10.9@124mph all motor, no turbo or NOS, theres noway thats 280bhp
i believe its a k24 engine, ie a 2.4 bottom end with a 2.0 head(off civic type r)
#54
http://www.youtube.com/watch?v=cfmmZ...eature=related
at 148mph thats not 300bhp, and thats a 2.4 N/A engine aswell
http://www.honda-tech.com/showthread.php?t=1880928
dyno showing a fair bit of power
yes these are all honda heads so they flow well but shows if you can get a YB head flowing well enough it will produce the power
#55
passionford pro
363bhp @ 8500 and 255lb ft @6000rpm on a 2.4 honda engine.
okay why does it and most other n/a 4 cyl seem to do max power at around 8500rpm (millington diamond 340bhp@8700 with 243lb ft on the 2.7l one)....could it be that thats about the limit of a 4cyl N/A engine in terms of airflow?? genuine question.bearing in mind greek boy is claiming 416bhp @12,200rpm and 200lb ft torque @ 9750.
#56
well give me a bit of time and ill have a look to find some more info on the first link as doing 148mph is not 350bhp, its an aweful lot more.
if it was a turbo car id guess it was making 600bhp
also the second link is 363whp, so about 400bhp at the fly.
here is a k series motor hitting 400bhp
it does seem to peak at around 8.5k like you say, but holds onto the power well
id say looking on honda-tech.com in the US is a good place to see where they are really pushing the N/A engines
#57
passionford pro
i am not doubting that the honda engines cant hit 400bhp, as you have posted,but look at the figures compared to greek guy. what i am saying is he is not hitting the figures hes claiming with a cossie engine...and it was back in 2006. the cossie is allegdly doing 180bhp @6k where the honda is doing 275@6k..the honda is over 180bhp at 5k...look at torque figs too
if you look at honda s2000 compared to a cossie....the ports on a s2ooo are massive and it was designed with N/A in mind.
#63
#64
My comments were very clearly that a YB engine, and specifically a yb head casting wont do that power, not that no engine possibly can do so, Ive got a lexus V8 that will piss 400bhp in N/A form with moderate tuning, I can stick a YB cam cover on the top of that but I still wouldnt call it a YB
#65
#66
some superb fabrication on the page of this site as well
http://www.kit-car-builds.socialgo.com/magazine.html
#70
Fixing the bloody car...
Are they claiming that's an Evo engine?
The pic looks very similar to one Dave Rowe from EPS showed Gary, taken when the Golf drag engine blew on the engine dyno. IIRC, he said they then made billet braces front and rear in order for the new lump to hold together.
Not sure what VAG lump it was though.
#72
I'm with chip here. I don't think on our dyno's the car would make over 400hp. I do however think its probably the highest powered n/a cossy. He reckoned in that thread he's seen 1.3-1.4 bar absolute on an n/a engine. I find that VERY hard to believe. Unless there was some random very high pressure that day in greece?
As chip said, nothing matters material wise, apart from the relatively small friction losses. Which are probably only 30-40hp MAX anyway, so totally removing these with exotic materials wouldn't give the type of gains he's seen.
I also question some of his parts. I.e. its easy for us to get pictures from random sites on the internet, the billet block for example. I've no doubt he's probably 1 of the most advanced tuners in the world. We'd all love his customer base.
He does make lots of references to old F1 turbo engines, i've also looked a lot into them, and they are truely YEARS ahead of "us" for example, they had vband back housing turbo's in the 80's. We got them a couple of years ago.
Sadly f1 isn't going back turbo I don't think. I wish it was, so the technology could phase down to us in 20 years time.
#75
i had a read at a Honda k24 that stroked it at 2.6 which made 424 N/A,all steel,even with a crazy piston/rod rate,over here in Greece,thank god we have very good tuners as far as engine builders/ECU tuning,they've done as you mention some crazy blue ovals,few LET's and Peugot 1.6T over 600hp some crazy turbo mini's (new) some corsa opc at about 600hp and some stroked ones to 1.8 to over 600hp,and vw1.8 20v at 700+
,and a few stroked to 2.0 vw.many of them are daily cars too !
#76
I am suprised that no one has made any comments regarding the Greek dyno graph. I have never seen such a dodgy looking graph. Engine torque output does not change like that.
Also the YB head does not have enough port cross sectional area to approach the airflow that Honda Kseries engines have. In fact there is not enough material at the inlet flange to get to 2 square inches. 2 sq. inches will flow 146 X 2 = 292 cfm @28" depression.
That is the reason HP limits are at the low to mid 300 hp range.
Honda heads are approaching - or exceeding 400 cfm @28"
#77
#78
JoeyBoyden
04-01-2024 02:36 PM
