whos westy/caterham who set fire at track day i think coombe?
Fuel rail bracket broke I believe causing the rail to pop out, there is a video on you tube from in the car !
Short of the mesh in the air vent and the filter I think that was the only damage as well ! lucky for sure.
Was mine Roosie.
Basically 1 of the small brackets that bolt to the fuel rail and the plenum sheared meaning the fuel rail could move. I have no idea when it broke but it allowed the rail to move away enough for the injector to pop out at the rail end. So I basically had an 044 pumping fuel straight through -6 hose into the engine bay until it eventually ignited to this!
VIDEO HERE
VIDEO HERE
Bloody hell, scarey stuff, all the fibreglass etc would've gone in no time if that bloe with the extinguisher wasn't there to respond so quickly!
Any idea how much a plumbed in fire extinguisher setup would weigh?
What rail have you got?
Sounds like its not bolted up right to push the injector fully in or the recess is not deep enough for the injector and o-ring to sit correct seated.
Stu
That all depends on what inlet your running though roosie and how it bolts up to the inlet. Mine doesn't bolt up to the normal mounts. The injector should fit snug in both ends with the O ring sitting well into the recess.
Stu
Stu
Out of interest, which system do you have fitted? It's something i'd not really considered until I read this thread, now i'd be very tempted to fit one post IVA.
Yours sounds like you don't have it bolted on correct causing too bigger gap and the injector to not sit proper.
Stu
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
