billet silvertop zetec oil pump gears
#46
I know but that's one of those things lol , I am starting to get the parts together to build 10 kits for stock but saying that most of them are spoken for
#50
Under the car...!
I thought people were saying dry sump kits were Ł2k plus?
http://www.burtonpower.com/tuning-gu...duct_group=196
Ł1120 for a full kit? or are there other parts that are needed?
#51
#52
They are , a kit cost from around Ł800 to Ł1500 then you got to get hose at a shed load per meter and then add fittings at a load more and then you have a shed load of other bits to get so to fit a full on good system/set up will cost at least 2k , if you do it for less then you have done well
#53
Under the car...!
cheers lads. I did think it was missing hosing, but thought sure;y it couldn't be sold as a kit without it...! lol
yeah, aeroquip and related stuff costs a fortune.
Back to plan B. Build it, if it breaks bin it and go YB or another engine.
#57
Under the car...!
#58
spec is probably all the thinngs everyone says don't do lol
but here it is,
silvertop zetec
375bhp ish not proven
lightweight flywheel
lightweight pully
originally ballanced bottom end but had a replaced clutch and flywheel in its life so not ballanced now
patten oil pump
2 bar of boost 7200rpm limiter
covered about 15 20k on road over 3 years
and hammered to death at pod with 100's of runs up strip cos always go 4 5 times a year
so whats everyone think to that lol
#59
i am quite willing to test anything on my car mate as without people trying new stuff nothing ever gets achived or tested, who cares about warrenty mate development is only way to learn!!
#60
but here it is,
silvertop zetec
lightweight pully
patten oil pump
but here it is,
silvertop zetec
lightweight pully
patten oil pump
Although out of interest: what size gudgeon pins are in your rods?
#61
1/4 mile beasty!!!!
#62
which months peformance ford is this external oil pump in?
need to be having a look!
what sort of price are kits going to retail at and does this use the original sump and just an external pump?
#63
Under the car...!
Well it's this months mag, It doesn't say anything about the external oil pump kit apart from it has one...! developed by burton iirc. It's a wet sump kit yes. I bet its gonna be pricey... best part of a grand I bet tho I could be wrong!!
#64
It was working on this already but burtons wanted one asap for that car , so it was not so much developed for burtons but they are the first person to use one , unfortunately the mag didn't cover it to well which was a shame ,never mind , the kit will be around a Ł1000 ( no more) but there is alot in it and it's going to be a buy and install and go kit, no hinden cost ,
The kit will incl
Blacktop steel pan/ modded
Pump bracket
Gear Pump
Pulley+belts
Stainless pipes/fittings
Oil in sandwich plate
Bolts
Std modded front cover
And other bits that I can't remember
The kit will incl
Pump bracket
Gear Pump
Pulley+belts
Bolts
#65
The kit will incl
Pump bracket
Gear Pump
Pulley+belts
Bolts
The kit will incl
Pump bracket
Gear Pump
Pulley+belts
Bolts
So this kit won't fit silver top engines without swapping sumps around etc as it sounds like ur only including the lower half of the sump pan and the front covers will be different to or am I wrong?
#66
For a silvertop you will need to put the alloy part of the blacktop sump on ( it does fit but you have to remove a part of cast webbing in the alloy part of sump ) , and I will carry stock on both front covers so this kit will fit black and silvertop engines , as the kit is designed with both engines in mind , also the kit should let you carry on running air con if you have it
#69
Its the harmonics of the high revs that is breaking them ...... they need putting eaither on a engine on the dyno witch is going to pull hight revs for a period of time or a race or rally engine....
#76
Zetec oil pump
It should be soon , the one in the pic is ians to test on a turbo engine , as the only other testing is on a n/a engine in time attack , it will fit silver and black tops but you will need to run a black top alloy pan of the pan ( which fits silver tops with a little work ) .
It is aiming at being a drive in/drive out kit if your good with a spanner .
Thanks mate for moving the pics over
