Xr4i diff question
Old Oct 12, 2010 | 07:48 AM
jonesymk2's Avatar
jonesymk2
Default Xr4i diff question
My mate has just blown the diff up on his xr4i,he wants to fit an LSD from a 2.9 xr4x4 but needs to know what drive shafts to use as the xr4i ones push into the diff and the others on the LSD bolt up to the flanges on the diff,will the flanges come out and then the xr4i shafts just push in or will he need to use the shafts and everything from the xr4x4
Old Oct 12, 2010 | 01:43 PM
Jim Galbally's Avatar
Jim Galbally
change the whole rear beam for one off the XR4x4 then it's easy to replace and also you get the disc brakes. simples
Old Oct 12, 2010 | 02:04 PM
Paulo P's Avatar
Paulo P
Exactly what I did, just remember that you will also need the rear shocks or to change the lower bushes.
Old Oct 12, 2010 | 03:05 PM
Jim Galbally
oh yeah, i changed all the suspension when i did mine as the donor car had konis on it
Old Oct 12, 2010 | 05:04 PM
If using 2wd shocks on 4wd arms simply use a 1/4" spacer each side of the bottom eye fixing, or 4wd shocks in 2wd arms cut 1/4" off each bottom eye tube part.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
