F*****g MOT!!!
#41
Is it true this is the most popular thread i've ever started...although not a very friendly one. My next post will be on how to win friends and influence people! lol
#44
having a mid life crisis
well the tester was doing his job as when u just swapped them over one was still not up to required standard.
well if you not use the rear seats take em out and the belts no problems then
#45
would that work? The way i understand it is if its fitted with them as standard they've gotta work
#47
Just looked at mot testers manual and apperantly if i take the rear seats out it will pass. Happy fucking days. All that abuse was worth it. Gotta love the internet!
#53
Point taken, but i need the motor for my job and having just paid mr darling his pound of fleesh i am proper skint and cannot afford a new motor.
#54
Ta fella. Your a life saver. A bit of constructive info, what i needed all along. Its nicer to help people out rather than slag em off surely. Mind being nice never got anyone anywhere and you lot have clearly had fun! lol
#57
Got to pay for another £20 re test. I can only assume mr tester will be spitting feathers. But seriously thanks for the tip. I am proper skinted and the rear seats are honestly never used.
#58
I hope for your sake mate that the tester doesnt go through the car again with an even finer tooth comb!
#60
YES I KNOW I CANT SPELL
Dont see how id go through the windscreen with it bein a rear belt. And it aint endangering no one as its a fucking works motor and i dont carry passengers. How can the tester say the offside one is fine and when i put the offside one on the nearside, it now fails when he previously said it was ok..answer me that one people.
#61
but if it dosent keep its self pulled tight to the passanger then?? ie does not rectract then you might as well not wair one!!! hes a tester for a reason mate you think he needs the ag of retesting you car time and time over??
#62
ST by Name and by Nature
Understand your frustration, wasn't a Mk3 Fiesta by any chance, my sisters had fault on hers years ago wouldn't retract, IIRC there was a fault with some Mk3 Fiesta seat belts? Just bought a new one and found out about problem with them after paid up, but glad just get safely working belt again.
#64
#65
If it retracts with being "fed" the belt is passes end of, it does NOT have to retract all on it's own, as a lot of older cars don't, if it does after being helped this is permissible.
#66
cossie fan (unluckerly)
a retractable seat belt has to retract on its own or it will not fit correctly say when u move forward and loosen it then it will be useless quote from vosa manual reasons for fail a retracting mechanism dose not retract the webbing sufficiently to remove all slack from the belt with the locking mechanism fastened and the seat unoccupied
#67
Without trying to be cocky,
If you never carry passengers, remove the rear seats before the test. If the seats aren't in the belts don't need testing. Simples.
Had my focus MOT'd with only a drivers seat in it and the belts flapping all over the place - passed no probs and didn't even get a raised eyebrow!
Chris
Chris
#68
Resident Wrestling Legend
and if it's your works motor why don't you get your work to sort it?
