cvh oil pump fiesta rs
550+ LUV IT!!!!!!!!!!!!!!
Do you need to take the sump off to change the oil pump.
And where is it on the engine.
Do these get weak? oil light is staying on a fraction to long for my
morning start up, bottom end full rebuild 4k ago but oil pump not changed.
Engine is so quite when running , could this be a weak pump.
CheeRS Rich
CheeRS Rich
More than likely worn out mate and not picking up straight away once its drained out a bit over night, really cant understand why people re-build engines then overlook the most vital part for the sake of saving £60, i know you can change the oil pump with the engine in place in a s2 rst but not sure about the frst.
why o why do i do it!!!!!
you can change the oil pump with the engine still in, but you have got to take the sump off, i would say only use a o.e sump gasket to make sure you get a good seal i would take the alternator off aswell
can be done in situ!bit of a fiddle !have to take the sump off to unbolt the pipe up pipe from the pump!
I always found the sump gasket on these a complete bitch!sump is easy to get on and off,the gasket sits in a slot the oil pump end and the gearbox end,the box end a right fiddly feck!best way is to use sealant and stick the gasket to the block then when the sealant gone off carefully put the sump on!
For you symtons i would be tempted to try a oil pressure switch first,prob wont cure it but they are cheap and easy to do got to be worth a shout!
big_Rad
15-09-2017 09:36 AM
