Can and crank position sensing set up.....
#41
DazC, The choices are...
1) Bottom pulley - you say you dont want to do this..
2) Flywheel change for efi - you say you dont want to do this either !!!!
3) Dizzi - You say you want to get rid of this
These are your ONLY options
#42
No Simon..
I want to do the bottom pulley but NOT Sierra stuff and I don't want to mess about dropping the engine mounts or taking the bottom pulley off every time I want to change the alternator belt.....I just wanted to see what options people can come up with on how to do the crank pulley so I know if I can get something easy enough (buy off the shelf type thing) or if I then have to go about re inventing the wheel.
Hope this clears it up for you!
#45
Ask me a question!
Hope this clears things up a bit
#48
All I want is to have crank angle sensing ability on the crank pulley....yet I don't want to encroach to close to the inner wing preventing space to slip a belt in...
If you mean the Sierra stuff, If I am to have the pulley adapted, I might as well make a toothed wheel and graft it to the original crank pulley.
#50
I do still want to run the standard timing belt cover though so not sure how to over come that one....
It fits no problem
#54
Spanner monkey
if you need, i'm back at work on the 4th and can mail you the dimensions for the holes and the bends etc?
will save you keep offering up to make sure it's fitting??
#55
Hi Gary! Some of that could be useful to me!! I shall bear it in mind when I weigh it all up. The management isn't going on immediately so I will assess my options next month sometime.
mike elsome
14-09-2015 04:08 PM
