BMW E30 cosworth conversions.
Got a decent 2 door facelift E30 shell sat in my garage, been there for a good 2-3 years now, mint shell jsut unsure what to do with it.
jsut wondering whats involved in sticking a YB in an E30, wiring wise? what diff to use? box? etc.....
any help of info is much appreciated
cheers Gaz
cheers Gaz
Unknown.
Friends one uses 325i sport rear end, Was on ebay a while back. Custom engine mounts made by himself, and he used a T5 cossie box with a modded prop.
Went like shit off a shovel running stage 3 power.
Gracelands built one in the past, I'm sure he'll be more helpful if he see's this.
yeah i would want it stage 3 mate, no more really.
do the 325's come with an lsd? unsure on how strong beemer diffs are you see, its something i've never looked into before.
jsut want to know what bits i need so i can start collecting and strip it over winter ready.
14000+ post superhero
i have a complete conversion ready to drop into an e30 that i removed from my touring for Ł1800. pretty much plug and play with the cosworth wiring loom connecting to the large socket on the original e30 loom.
22000 miles since new piston rings and stem seals, ported and polished head, 10000 mile since new stage 2 t34.48, 1000 miles on new grpA headgasket fitted after the head was removed to helicoil a couple of broken manifold studs . the custom mounts, custom prop, custom sump to fit around the standard front crossmember, t5 with modified bellhousing to make use of the original bmw hydraulic clutch system, stainless 2.5" straight through exhaust, recored standard rad and 2wd cooler, l6 ecu with stage1 chip ,lots of samco hoses and a 4 pipe breather kit all included.. as you can see from the pics the drive belts have been removed and the oil has been drained for a service whilst its out .
i had problems with my rear diff mount cracking, it needed strengthened which was no big deal really. i had a 3.91 lsd and it was quite fierce acceleration.
only the sport comes with an lsd as standard . it was an option on 325's when new. the 325 will have heavier suspension than other e30's in the range as standard . especially if you get an mtec equipped like my touring.
got bored of it. i stripped it down and broke it up about 2 months ago. i wasnt using it.all the car parts are gone . ive not really advertised the conversion parts much just in case i changed my mind.
yes, take it all away for Ł1800...
theres 2 small oil leaks, 1 from the front cam half moon seal and 1 from the output shaft on the rear of the t5. both easy enough fixes.
thats the only faults known to me. ive spent a few grand maintaining it over the 4 years ive had it.
its not a shiny show conversion but its a good honest functional engine that can be buftied up if thats your interest.
wish i had that sort of cash at the minute matey, was jsut going to do a project over winter through to mid next year.
would you sell the mounts and bell housing adaptor and sump seperate?
theres fierce talk about these recently!
it makes sense, combine a big power light(compared to the beemer 6's) engine with a good chassis is gonna make a fast car
and you dont get much better looking than a retro cool E30 on the right wheels!!
got some nice old school 7.5 or 8 inch cant remember..... 6 inch TSW hocks with the big metal centre caps will look rather goooood
You'd want to stick the E30 M3 front end suspension set-up on at least though surely? And with a Z3 or at least an E36 rack as well to make the most of it?
i'd find it hard to fault the 325 setup really, nothing wrong with it. z3 racks are often said to be too quick a rack and make the front end twitchy. e36 rack is a good improvement alright.
I've got a Z3 rack on my e36 as I found even the steering on that too 'slow' after the Cosworth and a few other cars I've had. The ratio on a std E36 is roughly the same as an E30 M3 ( about 3 and a half turns ). I find it pretty good now.....but it's still a slower ratio than the Sierra. The E30 M3 weights up a lot more as you turn in as well as it runs a lot more caster than a normal E30 so it gives it more 'feel' in my opinion as well.
When my friend owned his 325 Sport ages ago he put one of the Griffin Motorsport manual quick racks on and it seemed a lot more responsive. In those days there wasn't the option of a powered z3 rack
It seems like with the std E30 steering you have to put an armful of lock on to nip through a mini roundabout or quick left-right-left transition whereas it's just a flick of the wrists with a quicker ratio like in a Cosworth.
Just my two-pennorth though and I appreciate everyone likes different things on their car...but if I was going to do a YB conversion on an E30 I'd try and use the 'best' bits from the range
I s'pose it depends what you're used to Alan.
maybe the only slight disadvantage with putting the m3 setup in a standard car will be the wider track which would put the wheels out past standard arches. other than that it is an undoubtly better setup again
As for E36 racks there are three basic types that i think you could try depending on what you want.
The standard E36 rack as used on all the cars and also the E36 M3 EVO. These are around 3.4 turns lock to lock ( slightly less turns lock to lock on some cars like the M3 EVO and Sport if they have lock limiter tabs - may be around 3.2 turns...but the actual ratio is still the same )
The Z3 rack ( except for the Z3M ) which is basically the same but has a much faster ratio giving about 2.7ish turns lock to lock ( a lot of these have lock limiter tabs as many Z3s have big wheel/tyre options ). I think the Z3M has a ratio very similar to a normal E36.
There is also the non-EVO E36 M3 rack which is a variable ratio. This is very slow around the straight ahead position but much faster on extremes of lock - I think it gives about 3 turns lock to lock. It works OK with the E36 M3 front-end geometry which is peculiar to that car but it might give funny results on an E30. BMW changed the front-end geometry from the non-EVO to the EVO model when they used the linear rate rack.
IIRC the std E30 rack is a smidge over 4 turns lock to lock (4.1 ish). The E30 M3 rack is about 3.5/3.6 turns lock to lock but is obviously only LHD. When Birds converted E30 M3s to right hand drive they used the standard E30 rack which obviously diluted the steering response. I think they also had to modify the exhaust manifold quite a bit.
ZF who make the E36 steering racks usually express the rack ratios/speed in mm/rev. ( Milllimeters of movement per input revolution ) which is more useful perhaps to you as it tells you the speed of the rack without worrying about lock limiter tabs etc
A standard E36 rack is about 45mm/rev, a Z3 one is about 53mm/rev and the E36 M3 non-EVO one is about 39mm/rev until you have a lot of lock on when the ratio changes.
If you can get hold of a Z3 ( non-M model ) rack I'd try that but they are quite hard to get hold of as everyone has cottoned on to doing the mod now. If not, try a normal E36 one as will be an improvement in speed over a standard E30 one.
Alternatively the E46 Compact rack is about 2.9/3.0 turns lock to lock ( 50mm/rev ) and I think that should fit as well but probably best to look at it alongside an E36 one just to check the fittings. All E46 post 2001 racks shoud be the same as a Compact ( there were steering suspension mods to the E46 range midway 2001 to give better response - these mods were trialled on the Compact first ) but I stated the Compact as i know they are all that ratio.
Hope that is useful.
I went to a Z3 rack on my e36 328 and even though it is only about a half-turn quicker it feels much more than that and was a worthwhile mod for my use
if your wanting discs you can use the rear axle from any touring or a 325 saloon. all tourings have the good bits as standard and can often be overlooked because its an estate.
sounds good to me will find a tourer being broken.
any other bits worth having? is there 2 different bore shocker sizes too beetween models?
45mm and 51mm. only the 325 saloons have 51mm struts but again all tourings from 316's upto 325's use the bigger 51mm. the springs are 4 pot and 6 pot dependent though and rear springs on a touring are different rates to saloons
some thing to bare in mind, will more than likely be going on coilies anyway tbh but incase the funds get low am sure a decent shock and spring set up will be fine.
what did you do about the hydraulic clutch on yours? did you use a reyland kit or similar?
your not on e30zone? everything you need is on there.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
