cosworth keeps shuting down,HELP............
when the car boasts up it cuts out,does any1 kno what this could be,we turned the boast down & still does it?
HELP.......
HELP.......
the spec of what i kno is greens,polish/ported head,3 bar map senser,group A coil & stage 2 chip.think there is more but cant remember at min,
it only cut out when you floor it then it will do i loud pop out of exhaust.
we thought over boasting but still does it with low boast.
would it be ok to get it rolling road set up with this problem?
havent checked the senors.it does have a knock sensor in the block.are these any good or does it want getting rid off.
cheers
cheers
think there is a pipe blocked up on the amal valve.will check all pipes.its timed up spot on & all lugs are there.
what cps stand for?
what cps stand for?
considering your in derby you have one of the top cossie tuners around, on your doorstep
NMS http://www.norrismotorsport.co.uk/index2.html
be wise to take it there for a set up; they will find the problem if you cant
they are in Alfreton i think
excellent stuff mate,will give them a ring.
cheers for ya help
Adam Graham
06-09-2015 06:04 AM
