water cooled turbo or not
Plenty of cars run with no water cooling, just need to make sure your oil system can cope and ensure you run the car for a few minutes when you stop to stop heat soak into the bearings as the oil can be VERY hot and obviously engine stops = no oil being pumped around, or just take it easy for a couple of miles (off boost) before you get home, obviously water cooling is a benefit and if fitted properly can continue for ages after you switch off the engine, so I would recommend it, but then I have been running my twin turbo without it with no issues at all, just fitted an oil cooler to be sure the temps were kept stable.
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
19-08-2015 06:25 PM
