uk scooby pinking
Old May 12, 2009 | 05:38 PM
Kirbycossie's Avatar
Kirbycossie
Default uk scooby pinking
I have just bought a standard 1999 impreza turbo uk spec and it pinks under load and i do not know what would cause this. its running .6 of a bar of boost. also run only on super unleaded. any ideas would be gratefully received.
stacey
Old May 12, 2009 | 05:46 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Tbh i would take it to a scooby specialist and get a full checkover!
Old May 12, 2009 | 05:54 PM
jameswrx's Avatar
jameswrx
as it's a 99 I'd try MAF sensor (as they are almost consuables on that year)
If you replace it though make sure you reset the ECU.
Old May 12, 2009 | 06:00 PM
Kirbycossie
How do you reset the ecu?
Old May 12, 2009 | 06:21 PM
jameswrx's Avatar
jameswrx
I'd leave the battery unplugged for a few hours, you can do it with the plugs under the dashboard too have a look here for that method http://www.jollygreenmonster.com/ecu.asp.htm
You can try a quick check on the MAF (which isn't fool proof but has worked on cars I've worked on)
While the car is up to temp and idling, pull the electrical connector plug to the MAF sensor off, the car should cut out. If it just carries on idling it's supposed to signify a MAF fault as the ECU apparantly learns to sort of bypass the MAF when it's faulty (which is why you need an ECU reset after fitting a new one as your fault may persist)
If you do suspect a MAF fault (and remember they don't show up on the dash fault code light when checking like that) then one can be bought for Ł80 new, never buy a 2nd hand one as they brought out a revised one and if it's 2nd hand it'll prob be buggered too anyway.
Old May 12, 2009 | 06:47 PM
ECU Monitor Enthusiast
How do you know its pinking dangerously ? Knock link ? LOL
All scoobys will pink to a point as they have closed loop ignition.
Old May 12, 2009 | 07:17 PM
Kirbycossie
Just thought id ask as i know nowt bout scoobys and could hear slight pinking under load.
stacey
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
Bailes1992
Aug 16, 2015 07:14 PM
220TC
Sep 6, 2004 03:00 PM
TechnoDave
Jun 29, 2004 09:31 PM
